I'm trying to make the switch from Windows to GNU/linux. So far, I've installed Ubuntu, messed around with the command line a bit, and tried to install VirtualBox so I can run Windows 10 in a container and use it only for programs I can't run on linux or which run poorly on linux.
I've hit a snag. I tried to install VirtualBox but ran into some trouble. The install did not go successfully. Now I'm trying to remove VirtualBox via this command:
sudo apt-get remove virtualbox
The result is as follows:
Reading package lists... Done
Building dependency tree
Package 'virtualbox' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
Setting up virtualbox-6.0 (6.0.24-139119~Ubuntu~eoan) ...
dpkg: error processing package virtualbox-6.0 (--configure):
 installed virtualbox-6.0 package post-installation script subprocess returned error exit status 1
 virtualbox-6.0
I've tried the clean, remove, reinstall commands. No dice. Any help? Total noob here.
guiverc
  • 33,561
