I am trying to update Java on my Ubuntu server to Java 8, but I get an error message and Java wont update.
error message: Errors where encountered while processing E: Sub-process /usr/bin/dpkg returned an error code (1)
I used:
sudo add-apt-repository ppa:webupd8team/java
Then:
sudo apt update
Gave error:
Failed to fetch ......binary-amd64/Packages 404 not found
Failed to fetch ......binary-i386/Packages 404 not found
E: some files failed to download. Thay have been ignored,or old ones used instead.
Then:
sudo apt install oracle-java8-installer
Gave error:
I also tried sudo apt-get -f install and it gave this output:
Debconf : DbDriver "config" : /var/cache/deconf/config.dat is locked by another process: resource temorarily unavalable
Dpkg: error processing pacage openssh-server (--configure):
 Subprocess installed post-instalation script returned error exit status 2
 openssh-server
I have not used my 16.10 server for a year and it has not been updated in 2 years.
I used sudo apt-get update and got this output:
sijmen@dell:~$ sudo apt-get update
[sudo] password for sijmen:
Ign http: //ppa.launchpad.net trusty InRelease
Ign http: //ppa.launchpad.net trusty Release.gpg
Err http: //ppa.launchpad.net trusty/main amd64 Packages
  404  Not Found
Err http: //ppa.launchpad.net trusty/main i386 Packages
  404  Not Found
Ign http: //ppa.launchpad.net trusty/main Translation-en
W: Failed to fetch http:
/ppa.launchpad.net/thefrontiergroup/vsftpd/ubuntu/dists/trusty/main/binary-amd64/Packages  404  Not Found
/ppa.launchpad.net/thefrontiergroup/vsftpd/ubuntu/dists/trusty/main/binary-i386/Packages  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
Then I ran sudo apt-get install oracle-java-8-installer and it gave this output:
sijmen@dell:~$ sijmen@dell:~$ sudo apt-get install oracle-java-8-installer
WARNING:root:could not open file '/etc/apt/sources.list'
sijmen@dell:~$: command not found
sijmen@dell:~$ [sudo] password for sijmen:
[sudo]: command not found
sijmen@dell:~$ Reading package lists... Done
Reading: command not found
sijmen@dell:~$ Building dependency tree
Building: command not found
sijmen@dell:~$ Reading state information... Done
sijmen@dell:~$ E: Unable to locate package oracle-java-8-installer
WARN
E:: command not found
Then I ran sudo apt-add-repository --remove ppa:webupd8team/java and got this output.
sijmen@dell:~$ sudo apt-add-repository --remove ppa:webupd8team/java
 Oracle Java (JDK) Installer (automatically downloads and installs Oracle JDK7 / JDK8 / JDK9). There are no actual Java files in this PPA.
Important -> Why Oracle Java 7 And 6 Installers No Longer Work: http://www.webupd8.org/2017/06/why-oracle-java-7-and-  6-installers-no.html
Ubuntu 16.10 Yakkety Yak is no longer supported by Canonical (and thus, Launchpad and this PPA). The PPA supports Ubuntu 17.10, 17.04, 16.04, 14.04 and 12.04.
More info (and Ubuntu installation instructions):
- for Oracle Java 7: http: //www.webupd8.org/2012/01/install-oracle-java-jdk-7-in-ubuntu-via.html
- for Oracle Java 8: http: //www.webupd8.org/2012/09/install-oracle-java-8-in-ubuntu-via-ppa.html
Debian installation instructions:
- Oracle Java 7: http: //www.webupd8.org/2012/06/how-to-install-oracle-java-7-in-debian.html
- Oracle Java 8: http: //www.webupd8.org/2014/03/how-to-install-oracle-java-8-in-debian.html
Oracle Java 9 (for both Ubuntu and Debian): http://www.webupd8.org/2015/02/install-oracle-java-9-in-ubuntu-linux.html
Oracle JDK 9 is now considered stable. There are currently only 64bit builds (no other builds are available for download: http: //www.oracle.com/technetwork/java/javase/downloads/index.html )
 More info: https://launchpad.net/~webupd8team/+archive/ubuntu/java
Press [ENTER] to continue or ctrl-c to cancel removing it
WARNI    NG:root:could not open file '/etc/apt/sources.list'
Then I ran sudo apt-get update and it gave this output:
  404  Not Found
  404  Not Found
W: Failed to fetch http: //ppa.launchpad.net/thefrontiergroup/vsftpd/ubuntu/dists/trusty/main/binary-amd64/Packages  404  Not Found
W: Failed to fetch http: //ppa.launchpad.net/thefrontiergroup/vsftpd/ubuntu/dists/trusty/main/binary-i386/Packages  404  Not Found
Then I ran sudo apt-get install openjdk-8-jdk and it gave this output:
sijmen@dell:~$ sudo apt-get install openjdk-8-jdk
E: Unable to locate package openjdk-8-jdk
also for the current java version:
sijmen@dell:~$ java -version
java version "1.7.0_76"
Java(TM) SE Runtime Environment (build 1.7.0_76-b13)
Java HotSpot(TM) 64-Bit Server VM (build 24.76-b04, mixed mode)
karel
  • 122,292
  • 133
  • 301
  • 332
There is no package named oracle-java8-installer in ppa:webupd8team/java. The correct name of the package is oracle-java-8-installer. Open the terminal and type:
sudo apt update
sudo apt install oracle-java-8-installer
Alternatively you can install Java 8 from the default repositories in all currently supported versions of Ubuntu. Remove the ppa:webupd8team/java repository from your software sources with sudo apt-add-repository --remove ppa:webupd8team/java, update the package list with sudo apt-get update and run this command:
sudo apt install openjdk-8-jdk
If you still get the Debconf : DbDriver "config" : /var/cache/deconf/config.dat is locked by another process: resource temporarily unavailable error message then solve it by following the answers to "debconf: DbDriver "config": config.dat is locked by another process: Resource temporarily unavailable" while installing packages.
karel
  • 122,292
  • 133
  • 301
  • 332
These errors indicate that these two ppas no longer exist. Remove them from /etc/apt/sources.list and /etc/apt/sources.list.d
There is no reason to have them, since vsftp exists in the main repositories.
Also I suggest you upgrade to 17.10 since 16.10 isn't supported anymore.
Once the repositories were removed,
sudo apt update
should work, and then you can install Java 8.
