I had a power failure on my laptop, so I ended up crashing in the middle of a package installation. How do I fix this error?
jrg@atlantis:~$ sudo apt-get upgrade --fix-missing
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? Y
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
Setting up man-db (2.6.3-1) ...
dpkg: error processing man-db (--configure):
 subprocess installed post-installation script returned error exit status 1
 man-db
jrg@atlantis:~$
jrg
  • 61,707
