Attempted to add the Matlab installation and it asked me where my current installation was -- never have tried to install it before -- I hit cancel when it asked for the installation directory and now Ububtu Software Center bogs down the machine and everything in line to download and install behind it in the queue is hosed.
No places to hit pause or cancel for any of the line items. Just says "Applying Updates" and is in the list no matter what (I already closed out USC and restarted the machine several times). How should I proceed to get this out of the way? Is it an USC specific problem or an installation script problem? TIA
@dobey: I do not have matlab installed -- I was shopping on the USC, saw the matlab icon, tried to download the package. "Bogs down the machine" as in USC pulls 22% usage all by itself and the rest of the system suffers. The package is in limbo because it does not show as installed nor in history, so how do I kill the package from my USC download list?
@Daniel Llewellyn
Both commands say the same thing at the end: 1 not fully installed or removed debconf: DbDriver "config" /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
dpkg: error processing man-DB (--configure): sun process installed post-installation script returned error exit status 1
No apport report written because MaxRrports is reached already
Errors were encountered while processing: man-db
Tim
  • 33,500
Finally cleared it out after I noticed trying to install anything made the DbDriver complain and /opt subdirectories show a locked file -- went to the command line and installed synaptic which located the hung matlab install (after update and upgrade). Synaptic solved it behind the scenes. Hope that helps anyone else who runs into this issue in the future...
This sounds like the package is stuck mid-install.
From the commandline run sudo apt-get -f install to see if it clears the queue.
Once the queue is cleared, if you don't want matlab you can remove it again as normal: sudo apt-get remove matlab.
Doing this in the commandline may give you useful diagnostics information if things go pear-shaped again. (Usually a botched install will leave a log-file behind which lists every action it performed, and which action failed causing the early exit and the inconsistent state of apt.)
