Reading package lists... Done
Building dependency tree
The following packages will be REMOVED
virtualbox-6.0*
0 to upgrade, 0 to newly install, 1 to remove and 1 not to upgrade.
5 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another
process: Resource temporarily unavailable
Setting up libpam-systemd:amd64 (237-3ubuntu10.38) ...
dpkg: error processing package libpam-systemd:amd64 (--configure):
installed libpam-systemd:amd64 package post-installation script subprocess
returned error exit status 1
Setting up docker.io (18.09.7-0ubuntu1~18.04.4) ...
dpkg: error processing package docker.io (--configure):
installed docker.io package post-installation script subprocess returned error
exit status 1
Setting up mdadm (4.1~rc1-3~ubuntu18.04.4) ...
dpkg: error processing package mdadm (--configure):
installed mdadm package post-installation script subprocess returned error exit
status 1
Setting up bridge-utils (1.5-15ubuntu1) ...
dpkg: error processing package bridge-utils (--configure):
installed bridge-utils package post-installation script subprocess returned
error exit status 1
No apport report written because MaxReports has already been reached
dpkg: dependency problems prevent configuration of ubuntu-fan:
ubuntu-fan depends on bridge-utils; however:
Package bridge-utils is not configured yet.
dpkg: error processing package ubuntu-fan (--configure):
dependency problems - leaving unconfigured
docker.io
mdadm
bridge-utils
ubuntu-fan
Message given after command is ran
Ubuntu version 18.04
My lslocks:
`COMMAND PID TYPE SIZE MODE M START END PATH
blkmapd 540 POSIX WRITE 0 0 0 /run...
thermald 1295 POSIX WRITE 0 0 0 /run...
usbmuxd 2399 POSIX WRITE 0 0 0 /run...
teams 2123 POSIX WRITE 0 0 0
chrome 5478 POSIX WRITE 0 0 0
chrome 5478 POSIX READ 0 1073741826 1073742335
chrome 5478 POSIX WRITE 0 1073741825 1073741825
update-notifier 26233 FLOCK 0B WRITE 0 0 0
/run/user/1000/up
chrome 5478 POSIX WRITE 0 1073741824 1073742335
containerd 1532 FLOCK WRITE 0 0 0
gnome-shell 1847 FLOCK WRITE 0 0 0
/run/user/121...
whoopsie 6406 FLOCK WRITE 0 0 0
/run/lock...
teams 16728 POSIX READ 0 1073741826 1073742335
teams 16728 POSIX READ 0 128 128
lvmetad 545 POSIX WRITE 0 0 0 /run...
cron 1275 FLOCK WRITE 0 0 0 /run...
systemd-timesyn 1125 FLOCK WRITE 0 0 0 /run...
rpcbind 1124 FLOCK WRITE 0 0 0 /run...
frontend 8054 FLOCK WRITE 0 0 0
teams 2123 POSIX READ 0 1073741826 1073742335
teams 2123 POSIX WRITE 0 1073741825 1073741825
