The Package system is broken
The message I get when trying to run the software updater is as follows:
If you are using third party repositories then disable them, since they are a common source of problems. Now run the following command in a terminal: apt-get install -f Transaction failed: The package system is broken The following packages have unmet dependencies:
libc6-dbg: Depends: libc6 (= 2.27-3ubuntu1.4) but 2.27-3ubuntu1.3 is installed libc6-dev: Depends: libc6 (= 2.27-3ubuntu1.4) but 2.27-3ubuntu1.3 is installed Depends: libc-dev-bin (= 2.27-3ubuntu1.4) but 2.27-3ubuntu1.4 is installed
I disabled all third party repositories and ran the command:
Sudo apt-get install -f
and I got:
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable (Reading database ... 310312 files and directories currently installed.) Preparing to unpack .../libc6_2.27-3ubuntu1.4_amd64.deb ... De-configuring libc6:i386 (2.27-3ubuntu1.3) ... debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable dpkg: error processing archive /var/cache/apt/archives/libc6_2.27-3ubuntu1.4_amd64.deb (--unpack): new libc6:amd64 package pre-installation script subprocess returned error exit status 1 Preparing to unpack .../libc6_2.27-3ubuntu1.4_i386.deb ... De-configuring libc6:amd64 (2.27-3ubuntu1.3) ... debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable dpkg: error processing archive /var/cache/apt/archives/libc6_2.27-3ubuntu1.4_i386.deb (--unpack): new libc6:i386 package pre-installation script subprocess returned error exit status 1 Errors were encountered while processing: /var/cache/apt/archives/libc6_2.27-3ubuntu1.4_amd64.deb /var/cache/apt/archives/libc6_2.27-3ubuntu1.4_i386.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
So I am stuck. How can I recover from this serious crash? I am using Ubuntu 18.04.5 LTS
Many thanks
