I interrupted an installation, and now apt and apt-get don't work with any arguments. I always get the same error:
E: dpkg execution was interrupted, you must manually run "sudo dpkg --configure -a" to correct the problem.
EDIT :
I have tried to do sudo dpkg --configure -a and it only did
Setting up cento (1.5.181022-373) ...
Making the /var/log/cento directory...
(Re)Starting cento...
^Cdpkg: error processing package cento (--configure):
installed cento package post-installation script subprocess was interrupted
Setting up ntopng (3.7.181022-5357) ...
Rebuilding ld cache...
(Re)Starting ntopng...
^Cdpkg: error processing package ntopng (--configure):
installed ntopng package post-installation script subprocess was interrupted
Setting up pfring-dkms (7.3.0) ...
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
dpkg: error processing package pfring-dkms (--configure):
installed pfring-dkms package post-installation script subprocess returned error exit status 1
Processing triggers for libc-bin (2.27-3ubuntu1) ...
cento
ntopng
pfring-dkms
EDIT 2:
I have tried sudo apt install --reinstall cento and this is the exit:
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 9 not upgraded.
3 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
E: Internal Error, No file name for cento:amd64
EDIT 3:
I have made sudo fuser -v /var/cache/debconf/config.dat
USUARIO ORDEN DE ACCESO PID
/var/cache/debconf/config.dat:
root 2845 F.... frontend
Then I made sudo kill 2845(I do not get an answer)
Then I made sudo kill -9 2845
kill: (2845): No such process
Then I tried sudo apt autoremove:
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
4 not fully installed or removed.
Progress: [ 0%] [.............................................................]
And it stops there and doesn't do any more
