-1
Okay, so my ultimate goal is to install my Epson WF-2630 AIO printer. Upon trying to do this, I found that trying to install any package w/apt causes the same dependency error:
jen@DotySupreme:~/Downloads$ sudo dpkg -i epson-inkjet-printer-escpr_1.4.1-1lsb3.2_amd64.deb
(Reading database ... 223896 files and directories currently installed.)
Preparing to unpack epson-inkjet-printer-escpr_1.4.1-1lsb3.2_amd64.deb ...
Unpacking epson-inkjet-printer-escpr (1.4.1-1lsb3.2) over (1.4.1-1lsb3.2) ...
dpkg: dependency problems prevent configuration of epson-inkjet-printer-escpr:
 epson-inkjet-printer-escpr depends on lsb (>= 3.2); however:
  Package lsb is not configured yet.
dpkg: error processing package epson-inkjet-printer-escpr (--install):
 dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.23-0ubuntu7) ...
So I tried following instructions from several posts:
  1. apt-get install can't install any software
    • After reading this one, I think my error might be because I once ran autoremove, but I don't know how to shut it off.
  2. Apt-get fails to install any software since latest update
    • I don't think this one will help, because I don't have a process to kill.
  3. Errors when trying to install
    • The comment "@tlo I fixed it myself somr kind og command that's turns the terminal purpel and it say yes or no I choose yes and boom it fixed everything sudo dpkg -configue -a then sudo apt-get update" says that he answered his own question, but doesn't give me enough information to know what he did.
  4. How to install Epson printer drivers on Ubuntu 16.04?
    • I added the trusty sources, but it doesn't add the printer, and when I manually select either the .rpm or .deb, I get a list of dot matrix printers to choose from.
When I try to use the gui to install the printer, and tell it to download the drivers itself, it just sits there frozen.
I've run several commands:
jen@DotySupreme:~$ sudo apt-get install printer-driver-escpr
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 libgcc1:i386 : Depends: libc6:i386 (>= 2.2.4) but it is not going to be installed
 lsb-core : Depends: libc6:i386 or
                     libc6-i386 but it is not going to be installed
 zlib1g:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
N: Ignoring file '20auto-upgrades.ucf-dist' in directory '/etc/apt/apt.conf.d/' as it has an invalid filename extension
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
jen@DotySupreme:~$ sudo apt-get -f install
Correcting dependencies... Done
The following additional packages will be installed:
  libc6:i386
Suggested packages:
  glibc-doc:i386 locales:i386
The following NEW packages will be installed:
  libc6:i386
0 upgraded, 1 newly installed, 0 to remove and 57 not upgraded.
7 not fully installed or removed.
Need to get 0 B/2,275 kB of archives.
After this operation, 9,811 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
Preparing to unpack .../libc6_2.23-0ubuntu7_i386.deb ...
dpkg: error processing archive /var/cache/apt/archives/libc6_2.23-0ubuntu7_i386.deb (--unpack):
 subprocess new pre-installation script returned error exit status 1
jen@DotySupreme:~$ sudo apt-get update
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
jen@DotySupreme:~$ sudo dpkg --configure -a
dpkg: dependency problems prevent configuration of zlib1g:i386:
 zlib1g:i386 depends on libc6 (>= 2.4); however:
  Package libc6:i386 is not installed.
dpkg: error processing package zlib1g:i386 (--configure):
dpkg: dependency problems prevent configuration of lsb-core:
 lsb-core depends on libc6:i386 | libc6-i386; however:
  Package libc6-i386 is not installed.
 lsb-core depends on zlib1g:i386 | lib32z1; however:
  Package zlib1g:i386 is not configured yet.
  Package lib32z1 is not installed.
dpkg: error processing package lsb-core (--configure):
Setting up cups (2.1.3-4) ...
dpkg: error processing package cups (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of lsb:
 lsb depends on lsb-core (>= 9.20160110ubuntu0.2); however:
  Package lsb-core is not configured yet.
dpkg: error processing package lsb (--configure):
dpkg: dependency problems prevent configuration of libgcc1:i386:
 libgcc1:i386 depends on libc6 (>= 2.2.4); however:
dpkg: error processing package libgcc1:i386 (--configure):
dpkg: error processing package epson-inkjet-printer-escpr (--configure):
dpkg: dependency problems prevent configuration of lsb-printing:
 lsb-printing depends on lsb-core (>= 9.20160110ubuntu0.2); however:
dpkg: error processing package lsb-printing (--configure):
 zlib1g:i386
 lsb-core
 cups
 lsb
 libgcc1:i386
 lsb-printing
jen@DotySupreme:~$ sudo apt-get clean
UPDATE, tried to install synaptic:
jen@DotySupreme:~$ sudo apt install synaptic
[sudo] password for jen:
synaptic is already the newest version (0.83).
Keiva
  • 335
you are using epson-inkjet-printer-escpr_1.4.1-1lsb3.2_amd64.deb and the Epson website lists the epson-inkjet-printer-escpr_1.6.13-1lsb3.2_amd64.deb as the version they recommend http://download.ebz.epson.net/dsc/du/02/DriverDownloadInfo.do?LG2=EN&CN2=&DSCMI=55539&DSCCHK=5ef6ec128765534a989152269045f12fc58077f2 .so if you download and save that .for a new search,I start here http://download.ebz.epson.net/dsc/search/01/search/?OSC=LX and enter the printer number.
I see various error messages "ibc6:i386 is not installed"; and "Package lsb-core is not configured yet" please check lsb installed; ideally using synaptic which one can install with sudo apt install synapticand if lsb is installed I would try again in a terminal with sudo apt install epson-inkjet-printer-escpr_1.6.13-1lsb3.2_amd64.deb
new terminology I understand is to just use apt install
pdc
  • 1,132
