I was working in my laptop and suddenly it just went off.
When i reopened it directly gave a message of CMOS RESET 502 and it closed again.
I reopened after an hour and this message didn't appear but the issue now is that my gpu feels (from the heat and the fans going crazy) that it is running on 100%. And I am saying feels cause nvidia-smi doesnt work anymore as it gives:
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Also:
>>>nvidia-settings -q GPUUtilization -q useddedicatedgpumemory gives:
ERROR: NVIDIA driver is not loaded
Also:
>>>nvidia-settings
ERROR: Unable to load info from any available system
(nvidia-settings:8255): GLib-GObject-CRITICAL **: 20:06:12.090: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Some info:
>>>lsb_release -a --> Ubuntu 18.04.6 LTS
>>>lspci | grep VGA --> 01:00.0 VGA compatible controller: NVIDIA Corporation Device 1f50 (rev a1
>>>dkms status
nvidia, 470.161.03, 5.4.0-139-generic, x86_64: installed
nvidia, 470.161.03, 5.4.0-144-generic, x86_64: installed
v4l2loopback, 0.10.0, 5.4.0-139-generic, x86_64: installed
v4l2loopback, 0.10.0, 5.4.0-144-generic, x86_64: installed
Tried from this solution but failed with message that DbDriver is locked by another process:
>>> sudo dpkg-reconfigure nvidia-dkms-470
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
I also run the following (from @karen comment source):
>>>sudo fuser -v /var/cache/debconf/config.dat
/var/cache/debconf/config.dat:
root 9187 F.... frontend
frontend process which seems that is something that I am on secure boot related.
Any idea why is this happening? Is it only gpu or the OS is corrupted? How could i validate whats happening?
Thanks in advance
Edit
I managed to make it work by disabling the secure boot. But I dont get it why is this happening and how can I avoid the issue without disabling the secure boot?
