Hi maybe someone can help me solve my problem, I have a problem with dpkg
To fix the problem should I remove one by one the each of package mentioned in the output?
I have tried to run command sudo dpkg --configure -a sudo apt install -f
And I always get the same error message.
Whole output
    sudo apt-get clean && sudo apt-get autoremove
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 37 not upgraded.
11 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
Setting up libssl1.1:amd64 (1.1.1f-1ubuntu2.10) ...
dpkg: error processing package libssl1.1:amd64 (--configure):
 installed libssl1.1:amd64 package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of libfreerdp2-2:amd64:
 libfreerdp2-2:amd64 depends on libssl1.1 (>= 1.1.0); however:
  Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package libfreerdp2-2:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libwinpr2-2:amd64: libwinpr2-2:amd64 depends on libssl1.1 (>= 1.1.0); however: Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package libwinpr2-2:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of linux-headers-5.11.0-41-generic: linux-headers-5.11.0-41-generic depends on libssl1.1 (>= 1.1.0); however: Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package linux-headers-5.11.0-41-generic (--configure): dependency problems - leaving unconfigured Setting up ubuntu-advantage-tools (27.4.2~20.04.1) ... No apport report written because the error message indicates its a followup error from a previous failure. No apport report written because the error message indicates its a followup error from a previous failure. No apport report written because MaxReports is reached already debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable dpkg: error processing package ubuntu-advantage-tools (--configure): installed ubuntu-advantage-tools package post-installation script subprocess returned error exit status 1 No apport report written because MaxReports is reached already dpkg: dependency problems prevent configuration of openssl: openssl depends on libssl1.1 (>= 1.1.1); however: Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package openssl (--configure): dependency problems - leaving unconfigured Setting up xserver-xorg-legacy (2:1.20.13-1ubuntu1~20.04.2) ... No apport report written because MaxReports is reached already debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable dpkg: error processing package xserver-xorg-legacy (--configure): installed xserver-xorg-legacy package post-installation script subprocess returned error exit status 1 No apport report written because MaxReports is reached already dpkg: dependency problems prevent configuration of libfreerdp-client2-2:amd64: libfreerdp-client2-2:amd64 depends on libfreerdp2-2 (>= 2.1.0+dfsg1); however: Package libfreerdp2-2:amd64 is not configured yet. libfreerdp-client2-2:amd64 depends on libwinpr2-2 (>= 2.1.0+dfsg1); however: Package libwinpr2-2:amd64 is not configured yet.
dpkg: error processing package libfreerdp-client2-2:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of wget: wget depends on libssl1.1 (>= 1.1.0); however: Package libssl1.1:amd64 is not configured yet.
No apport report written because MaxReports is reached already No apport report written because MaxReports is reached already dpkg: error processing package wget (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of linux-headers-generic-hwe-20.04: linux-headers-generic-hwe-20.04 depends on linux-headers-5.11.0-41-generic; however: Package linux-headers-5.11.0-41-generic is not configured yet.
dpkg: error processing package linux-headers-generic-hwe-20.04 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of linux-generic-hwe-20.04: linux-generic-hwe-20.04 depends on linux-headers-generic-hwe-20.04 (= 5.11.0.41.45~20.04.19); however: Package linux-headers-generic-hwe-20.04 is not configured yet.
dpkg: error processing package linux-generic-hwe-20.04 (--configure): dependency problems - leaving unconfigured No apport report written because MaxReports is reached already No apport report written because MaxReports is reached already dpkg: dependency problems prevent processing triggers for ca-certificates: ca-certificates depends on openssl (>= 1.1.1); however: Package openssl is not configured yet.
dpkg: error processing package ca-certificates (--configure): dependency problems - leaving triggers unprocessed No apport report written because MaxReports is reached already Processing triggers for libc-bin (2.31-0ubuntu9.2) ... Errors were encountered while processing: libssl1.1:amd64 libfreerdp2-2:amd64 libwinpr2-2:amd64 linux-headers-5.11.0-41-generic ubuntu-advantage-tools openssl xserver-xorg-legacy libfreerdp-client2-2:amd64 wget linux-headers-generic-hwe-20.04 linux-generic-hwe-20.04 ca-certificates E: Sub-process /usr/bin/dpkg returned an error code (1)
karel
  • 122,292
  • 133
  • 301
  • 332
nocnica
