I try to use sudo apt upgrade this is the output:
lnee@fallback:~$ sudo apt upgrade
[sudo] password for lnee:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
  libodbc1
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
Setting up ca-certificates (20201027ubuntu0.20.04.1) ...
dpkg: error processing package ca-certificates (--configure):
 installed ca-certificates package post-installation script subprocess returned error exit status 1
Setting up grub-efi-amd64 (2.04-1ubuntu26.6) ...
dpkg: error processing package grub-efi-amd64 (--configure):
 installed grub-efi-amd64 package post-installation script subprocess returned error exit status 1
Setting up anbox-modules-dkms (13) ...
dpkg: error processing package anbox-modules-dkms (--configure):
 installed anbox-modules-dkms package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of grub-efi-amd64-signed:
 grub-efi-amd64-signed depends on grub-efi-amd64 | grub-pc; however:
  Package grub-efi-amd64 is not configured yet.
  Package grub-pc is not installed.
dpkg: error processing package grub-efi-amd64-signed (--configure): dependency problems - leaving unconfigured No apport report written because MaxReports is reached already dpkg: dependency problems prevent processing triggers for shim-signed: shim-signed depends on grub-efi-amd64-signed | grub-efi-arm64-signed; however: Package grub-efi-amd64-signed is not configured yet. Package grub-efi-arm64-signed is not installed.
dpkg: error processing package shim-signed (--configure): dependency problems - leaving triggers unprocessed No apport report written because MaxReports is reached already Errors were encountered while processing: ca-certificates grub-efi-amd64 anbox-modules-dkms grub-efi-amd64-signed shim-signed E: Sub-process /usr/bin/dpkg returned an error code (1) lnee@fallback:~$
FedKad
  • 13,420
lnee
  • 878
(note found this later this does not work the error was still there) So I first ran the command
sudo fuser -v /var/cache/debconf/config.dat
and I got this
/var/cache/debconf/config.dat:
USER        PID ACCESS COMMAND
root      40970 F.... frontend
and so i got the process id (40970) and killed it sudo kill 40970 (insert the process id).
Then I did sudo apt upgrade
and then I got this
Configuring grub-efi-amd64 GRUB failed to install to the following devices: /dev/sda2
Do you want to continue anyway?
If you do, your computer may not start up properly.
Writing GRUB to boot device failed - continue? <Yes> <No>
So I pressed <No>, then <Ok> and I think it's fixed.
lnee
  • 878
