I am trying to run sudo apt-get upgrade -y but it produces the below error
jamshaid@jamshaid:~$ sudo apt-get upgrade -y
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
6 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
Setting up ca-certificates (20201027ubuntu0.20.04.1) ...
dpkg: error processing package ca-certificates (--configure):
installed ca-certificates package post-installation script subprocess returned error exit status 1
Setting up grub-efi-amd64 (2.04-1ubuntu26.6) ...
dpkg: error processing package grub-efi-amd64 (--configure):
installed grub-efi-amd64 package post-installation script subprocess returned error exit status 1
Setting up cryptsetup-initramfs (2:2.2.2-3ubuntu2.3) ...
dpkg: error processing package cryptsetup-initramfs (--configure):
installed cryptsetup-initramfs package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of snapd:
snapd depends on ca-certificates; however:
Package ca-certificates is not configured yet.
dpkg: error processing package snapd (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of grub-efi:
grub-efi depends on grub-efi-amd64 (= 2.04-1ubuntu26.6); however:
Package grub-efi-amd64 is not configured yet.
dpkg: error processing package grub-efi (--configure):
dpkg: dependency problems prevent configuration of grub-efi-amd64-signed:
grub-efi-amd64-signed depends on grub-efi-amd64 | grub-pc; however:
Package grub-pc is not installed.
dpkg: error processing package grub-efi-amd64-signed (--configure):
No apport report written because MaxReports is reached already
ca-certificates
grub-efi-amd64
snapd
grub-efi
Mabe, it got corrupted when I tried to install Oracle VM and it installed python-2 and downgrade the grub to 2.x version. I didn't pay attention at that moment but having serious problems now. My mouse is not clicking outside the current window. Any solution to this? thanks
