lurkingandjerking@rad-pad:~$ sudo apt-get install ubuntu-restricted-extras
[sudo] password for lurkingandjerking:
Reading package lists... Done
Building dependency tree
ubuntu-restricted-extras is already the newest version (66).
The following package was automatically installed and is no longer required:
  lsdvd
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
41 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
Setting up libpam-systemd:amd64 (237-3ubuntu10.23) ...
dpkg: error processing package libpam-systemd:amd64 (--configure):
 installed libpam-systemd:amd64 package post-installation script subprocess returned error exit status 1
Setting up cups (2.2.7-1ubuntu2.6) ...
dpkg: error processing package cups (--configure):
 installed cups package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of dbus-user-session:
 dbus-user-session depends on libpam-systemd; however:
  Package libpam-systemd:amd64 is not configured yet.
dpkg: error processing package dbus-user-session (--configure):
 dependency problems - leaving unconfigured
Setting up cups-bsd (2.2.7-1ubuntu2.6) ...
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: error processing package cups-bsd (--configure):
 installed cups-bsd package post-installation script subprocess returned error exit status 1
Processing triggers for libc-bin (2.27-3ubuntu1) ...
No apport report written because MaxReports is reached already
                                                              Setting up libssl1.1:amd64 (1.1.1-1ubuntu2.1~18.04.3) ...
dpkg: error processing package libssl1.1:amd64 (--configure):
 installed libssl1.1:amd64 package post-installation script subprocess returned error exit status 1
Setting up libssl1.1:i386 (1.1.1-1ubuntu2.1~18.04.3) ...No apport report written because MaxReports is reached already
dpkg: error processing package libssl1.1:i386 (--configure):
 installed libssl1.1:i386 package post-installation script subprocess returned error exit status 1
        dpkg: dependency problems prevent configuration of python-cryptography:
 python-cryptography depends on libssl1.1 (>= 1.1.1); however:
  Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package python-cryptography (--configure):
dpkg: dependency problems prevent configuration of libdns-export1100:
 libdns-export1100 depends on libssl1.1 (>= 1.1.0); however:
dpkg: error processing package libdns-export1100 (--configure):
dpkg: dependency problems prevent configuration of openssl:
 openssl depends on libssl1.1 (>= 1.1.1); however:
dpkg: error processing package openssl (--configure):
Setting up libdvd-pkg (1.4.2-1-1) ...
dpkg: error processing package libdvd-pkg (--configure):
 installed libdvd-pkg package post-installation script subprocess returned error exit status 1
                                                              dpkg: dependency problems prevent configuration of libdns1100:amd64:
 libdns1100:amd64 depends on libssl1.1 (>= 1.1.0); however:
dpkg: error processing package libdns1100:amd64 (--configure):
                                                              dpkg: dependency problems prevent configuration of libpython2.7-stdlib:amd64:
 libpython2.7-stdlib:amd64 depends on libssl1.1 (>= 1.1.0); however:
dpkg: error processing package libpython2.7-stdlib:amd64 (--configure):
dpkg: dependency problems prevent configuration of bind9-host:
 bind9-host depends on libdns1100 (= 1:9.11.3+dfsg-1ubuntu1.8); however:
  Package libdns1100:amd64 is not configured yet.
dpkg: error processing package bind9-host (--configure):
dpkg: dependency problems prevent configuration of python3-cryptography:No apport report written because MaxReports is reached already
 python3-cryptography depends on libssl1.1 (>= 1.1.1); however:
dpkg: error processing package python3-cryptography (--configure):
dpkg: dependency problems prevent configuration of libisc169:amd64:
 libisc169:amd64 depends on libssl1.1 (>= 1.1.0); however:
dpkg: error processing package libisc169:amd64 (--configure):
dpkg: dependency problems prevent configuration of libisccc160:amd64:No apport report written because MaxReports is reached already
 libisccc160:amd64 depends on libisc169 (= 1:9.11.3+dfsg-1ubuntu1.8); however:
  Package libisc169:amd64 is not configured yet.
dpkg: error processing package libisccc160:amd64 (--configure):
dpkg: dependency problems prevent configuration of libqt5network5:amd64:No apport report written because MaxReports is reached already
 libqt5network5:amd64 depends on libssl1.1; however:
dpkg: error processing package libqt5network5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libnet-ssleay-perl:No apport report written because MaxReports is reached already
 libnet-ssleay-perl depends on libssl1.1 (>= 1.1.1); however:
dpkg: error processing package libnet-ssleay-perl (--configure):
dpkg: dependency problems prevent configuration of libisc-export169:amd64:No apport report written because MaxReports is reached already
 libisc-export169:amd64 depends on libssl1.1 (>= 1.1.0); however:
dpkg: error processing package libisc-export169:amd64 (--configure):
dpkg: dependency problems prevent configuration of libirs160:amd64:No apport report written because MaxReports is reached already
 libirs160:amd64 depends on libisc169 (= 1:9.11.3+dfsg-1ubuntu1.8); however:
 libirs160:amd64 depends on libdns1100 (>= 1:9.11.3+dfsg); however:
dpkg: error processing package libirs160:amd64 (--configure):
dpkg: dependency problems prevent configuration of libcurl4:amd64:No apport report written because MaxReports is reached already
 libcurl4:amd64 depends on libssl1.1 (>= 1.1.0); however:
dpkg: error processing package libcurl4:amd64 (--configure):
dpkg: dependency problems prevent configuration of libbind9-160:amd64:No apport report written because MaxReports is reached already
 libbind9-160:amd64 depends on libdns1100 (= 1:9.11.3+dfsg-1ubuntu1.8); however:
 libbind9-160:amd64 depends on libisc169 (= 1:9.11.3+dfsg-1ubuntu1.8); however:
dpkg: error processing package libbind9-160:amd64 (--configure):
dpkg: dependency problems prevent configuration of python2.7:No apport report written because MaxReports is reached already
 python2.7 depends on libpython2.7-stdlib (= 2.7.15-4ubuntu4~18.04); however:
  Package libpython2.7-stdlib:amd64 is not configured yet.
dpkg: error processing package python2.7 (--configure):
dpkg: dependency problems prevent configuration of dnsutils:No apport report written because MaxReports is reached already
 dnsutils depends on bind9-host | host; however:
  Package bind9-host is not configured yet.
  Package host is not installed.
  Package bind9-host which provides host is not configured yet.
 dnsutils depends on libbind9-160 (= 1:9.11.3+dfsg-1ubuntu1.8); however:
  Package libbind9-160:amd64 is not configured yet.
 dnsutils depends on libdns1100 (= 1:9.11.3+dfsg-1ubuntu1.8); however:
 dnsutils depends on libisc169 (= 1:9.11.3+dfsg-1ubuntu1.8); however:
 dnsutils depends on libirs160 (>= 1:9.10.6+dfsg); however:
  Package libirs160:amd64 is not configured yet.
dpkg: error processing package dnsutils (--configure):
dpkg: dependency problems prevent configuration of libio-socket-ssl-perl:No apport report written because MaxReports is reached already
 libio-socket-ssl-perl depends on libnet-ssleay-perl (>= 1.84-1ubuntu0.1); however:
  Package libnet-ssleay-perl is not configured yet.
 libio-socket-ssl-perl depends on libssl1.1 (>= 1.1.1); however:
dpkg: error processing package libio-socket-ssl-perl (--configure):
dpkg: dependency problems prevent configuration of libpython3.6-minimal:amd64:No apport report written because MaxReports is reached already
 libpython3.6-minimal:amd64 depends on libssl1.1 (>= 1.1.1); however:
dpkg: error processing package libpython3.6-minimal:amd64 (--configure):
dpkg: dependency problems prevent configuration of libisccfg160:amd64:No apport report written because MaxReports is reached already
 libisccfg160:amd64 depends on libdns1100 (= 1:9.11.3+dfsg-1ubuntu1.8); however:
 libisccfg160:amd64 depends on libisc169 (= 1:9.11.3+dfsg-1ubuntu1.8); however:
 libisccfg160:amd64 depends on libisccc160 (= 1:9.11.3+dfsg-1ubuntu1.8); however:
  Package libisccc160:amd64 is not configured yet.
dpkg: error processing package libisccfg160:amd64 (--configure):
dpkg: dependency problems prevent configuration of openvpn:No apport report written because MaxReports is reached already
 openvpn depends on libssl1.1 (>= 1.1.0); however:
dpkg: error processing package openvpn (--configure):
dpkg: dependency problems prevent configuration of libqt5gui5:amd64:No apport report written because MaxReports is reached already
 libqt5gui5:amd64 depends on libqt5network5 (>= 5.0.2); however:
  Package libqt5network5:amd64 is not configured yet.
dpkg: error processing package libqt5gui5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libpython2.7:amd64:No apport report written because MaxReports is reached already
 libpython2.7:amd64 depends on libpython2.7-stdlib (= 2.7.15-4ubuntu4~18.04); however:
dpkg: error processing package libpython2.7:amd64 (--configure):
dpkg: dependency problems prevent configuration of libpython2.7-dev:amd64:No apport report written because MaxReports is reached already
 libpython2.7-dev:amd64 depends on libpython2.7-stdlib (= 2.7.15-4ubuntu4~18.04); however:
 libpython2.7-dev:amd64 depends on libpython2.7 (= 2.7.15-4ubuntu4~18.04); however:
  Package libpython2.7:amd64 is not configured yet.
dpkg: error processing package libpython2.7-dev:amd64 (--configure):
dpkg: dependency problems prevent configuration of qt5-gtk-platformtheme:amd64:No apport report written because MaxReports is reached already
 qt5-gtk-platformtheme:amd64 depends on libqt5gui5 (= 5.9.5+dfsg-0ubuntu2.1); however:
  Package libqt5gui5:amd64 is not configured yet.
dpkg: error processing package qt5-gtk-platformtheme:amd64 (--configure):
dpkg: dependency problems prevent configuration of python2.7-dev:No apport report written because MaxReports is reached already
 python2.7-dev depends on python2.7 (= 2.7.15-4ubuntu4~18.04); however:
  Package python2.7 is not configured yet.
 python2.7-dev depends on libpython2.7-dev (= 2.7.15-4ubuntu4~18.04); however:
  Package libpython2.7-dev:amd64 is not configured yet.
 python2.7-dev depends on libpython2.7 (= 2.7.15-4ubuntu4~18.04); however:
dpkg: error processing package python2.7-dev (--configure):
dpkg: dependency problems prevent configuration of libpython3.6-stdlib:amd64:No apport report written because MaxReports is reached already
 libpython3.6-stdlib:amd64 depends on libpython3.6-minimal (= 3.6.8-1~18.04.1); however:
  Package libpython3.6-minimal:amd64 is not configured yet.
dpkg: error processing package libpython3.6-stdlib:amd64 (--configure):
dpkg: dependency problems prevent configuration of python3.6:No apport report written because MaxReports is reached already
 python3.6 depends on libpython3.6-stdlib (= 3.6.8-1~18.04.1); however:
  Package libpython3.6-stdlib:amd64 is not configured yet.
dpkg: error processing package python3.6 (--configure):
dpkg: dependency problems prevent configuration of samba-libs:amd64:No apport report written because MaxReports is reached already
 samba-libs:amd64 depends on libpython2.7 (>= 2.7); however:
dpkg: error processing package samba-libs:amd64 (--configure):
dpkg: dependency problems prevent configuration of libqt5widgets5:amd64:No apport report written because MaxReports is reached already
 libqt5widgets5:amd64 depends on libqt5gui5 (>= 5.9.0~beta); however:
dpkg: error processing package libqt5widgets5:amd64 (--configure):
dpkg: dependency problems prevent configuration of curl:No apport report written because MaxReports is reached already
 curl depends on libcurl4 (= 7.58.0-2ubuntu3.7); however:
  Package libcurl4:amd64 is not configured yet.
dpkg: error processing package curl (--configure):
dpkg: dependency problems prevent configuration of python3.6-minimal:No apport report written because MaxReports is reached already
 python3.6-minimal depends on libpython3.6-minimal (= 3.6.8-1~18.04.1); however:
dpkg: error processing package python3.6-minimal (--configure):
dpkg: dependency problems prevent configuration of libsmbclient:amd64:No apport report written because MaxReports is reached already
 libsmbclient:amd64 depends on samba-libs (= 2:4.7.6+dfsg~ubuntu-0ubuntu2.11); however:
  Package samba-libs:amd64 is not configured yet.
dpkg: error processing package libsmbclient:amd64 (--configure):
dpkg: dependency problems prevent configuration of mplayer:No apport report written because MaxReports is reached already
 mplayer depends on libsmbclient (>= 2:4.0.3+dfsg1); however:
  Package libsmbclient:amd64 is not configured yet.
dpkg: error processing package mplayer (--configure):
Processing triggers for libc-bin (2.27-3ubuntu1) ...No apport report written because MaxReports is reached already
 cups
 dbus-user-session
 cups-bsd
 libssl1.1:amd64
 libssl1.1:i386
 python-cryptography
 libdns-export1100
 openssl
 libdvd-pkg
 libdns1100:amd64
 bind9-host
 libisc169:amd64
 libisccc160:amd64
 libnet-ssleay-perl
 libirs160:amd64
 libcurl4:amd64
 libbind9-160:amd64
 python2.7
 dnsutils
 libisccfg160:amd64
 openvpn
 libqt5gui5:amd64
 libpython2.7:amd64
 python2.7-dev
 python3.6
 samba-libs:amd64
 curl
 python3.6-minimal
 libsmbclient:amd64
 mplayer
lurkingandjerking@rad-pad:~$ sudo /usr/share/doc/libdvdread4/install-css.sh
sudo: /usr/share/doc/libdvdread4/install-css.sh: command not found
lurkingandjerking@rad-pad:~$ sudo apt-get update
Hit:1 http://us.archive.ubuntu.com/ubuntu bionic InRelease
Get:2 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Hit:3 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic InRelease
Get:4 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Ign:5 http://download.opensuse.org/repositories/home:/strycore/xUbuntu_16.04  InRelease
Hit:6 http://download.opensuse.org/repositories/home:/strycore/xUbuntu_16.04  Release
Ign:7 http://ppa.launchpad.net/mc3man/trusty-media/ubuntu bionic InRelease
Ign:8 http://ppa.launchpad.net/me-davidsansome/clementine/ubuntu bionic InRelease
Hit:9 http://deb.playonlinux.com trusty InRelease
Hit:10 http://ppa.launchpad.net/papirus/papirus/ubuntu bionic InRelease
Ign:11 http://ppa.launchpad.net/pmcenery/ppa/ubuntu bionic InRelease
Hit:12 http://ppa.launchpad.net/stebbins/handbrake-releases/ubuntu bionic InRelease
Ign:13 http://ppa.launchpad.net/tiheum/equinox/ubuntu bionic InRelease
Ign:14 http://ppa.launchpad.net/tualatrix/ppa/ubuntu bionic InRelease
Hit:15 http://ppa.launchpad.net/ubuntuhandbook1/apps/ubuntu bionic InRelease
Ign:16 http://ppa.launchpad.net/videolan/stable-daily/ubuntu bionic InRelease
Err:17 http://ppa.launchpad.net/mc3man/trusty-media/ubuntu bionic Release
  404  Not Found [IP: 91.189.95.83 80]
Err:18 http://ppa.launchpad.net/me-davidsansome/clementine/ubuntu bionic Release
Err:19 http://ppa.launchpad.net/pmcenery/ppa/ubuntu bionic Release
Get:20 http://us.archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages [658 kB]
Err:21 http://ppa.launchpad.net/tiheum/equinox/ubuntu bionic Release
Err:22 http://ppa.launchpad.net/tualatrix/ppa/ubuntu bionic Release
Get:23 http://us.archive.ubuntu.com/ubuntu bionic-updates/main i386 Packages [544 kB]
Get:24 http://us.archive.ubuntu.com/ubuntu bionic-updates/main amd64 DEP-11 Metadata [278 kB]
Err:25 http://ppa.launchpad.net/videolan/stable-daily/ubuntu bionic Release
Get:26 http://us.archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 48x48 Icons [66.7 kB]
Get:27 http://us.archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 64x64 Icons [127 kB]
Get:28 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages [958 kB]
Get:29 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe i386 Packages [943 kB]
Get:30 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 DEP-11 Metadata [245 kB]
Get:31 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 48x48 Icons [198 kB]
Get:32 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 64x64 Icons [417 kB]
Get:33 http://us.archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 DEP-11 Metadata [2,464 B]
Get:35 http://security.ubuntu.com/ubuntu bionic-security/main amd64 DEP-11 Metadata [17.9 kB]
Get:36 http://security.ubuntu.com/ubuntu bionic-security/main DEP-11 64x64 Icons [25.6 kB]
Get:37 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 DEP-11 Metadata [36.2 kB]
Get:38 http://security.ubuntu.com/ubuntu bionic-security/universe DEP-11 48x48 Icons [16.4 kB]
Get:39 http://security.ubuntu.com/ubuntu bionic-security/universe DEP-11 64x64 Icons [104 kB]
Get:40 http://security.ubuntu.com/ubuntu bionic-security/multiverse amd64 DEP-11 Metadata [2,460 B]
E: The repository 'http://ppa.launchpad.net/mc3man/trusty-media/ubuntu bionic Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://ppa.launchpad.net/me-davidsansome/clementine/ubuntu bionic Release' does not have a Release file.
E: The repository 'http://ppa.launchpad.net/pmcenery/ppa/ubuntu bionic Release' does not have a Release file.
E: The repository 'http://ppa.launchpad.net/tiheum/equinox/ubuntu bionic Release' does not have a Release file.
E: The repository 'http://ppa.launchpad.net/tualatrix/ppa/ubuntu bionic Release' does not have a Release file.
E: The repository 'http://ppa.launchpad.net/videolan/stable-daily/ubuntu bionic Release' does not have a Release file.
Now this pops up
Zanna
  • 72,312
