So recently I was just setting up an Ubuntu 15.10 system, and I was downloading some stuff. There was a prompt to update some stuff, and I accepted it, and it went running while I was browsing some stuff in firefox. I was running a sudo command that I found when I was searching for something that will get rid of the Intel Haswell Mobile drivers and get the Intel HD Graphics 4000 drivers that my Windows 10 system had. (Windows has nothing to do with the situation, I just wanted the correct drivers and not one that would limit my fps to 60 and have glitches.) But while I was attempting that, the Software Update dialogue turned to the black dim that represents not responding, and I clicked on the X. It asked if I wanted to wait for it to respond or force quit, and I force quitted after a few minutes. Then, like it actually updated, I went to the Software Center to get some apps that I needed. I started to install the Synaptic Package Manager to get some updates for the updates that didn't get installed and possibly my drivers, but then it showed a dialogue that was titled, Package operation failed and said The installation or removal of a software package failed. Then I tried installing GIMP, and it said the same thing. Here's the details of the Synaptic Package Manager when I tried to install it.
installArchives() failed: debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
Selecting previously unselected package synaptic.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 212718 files and directories currently installed.)
Preparing to unpack .../synaptic_0.81.4build2_amd64.deb ...
Unpacking synaptic (0.81.4build2) ...
Processing triggers for hicolor-icon-theme (0.15-0ubuntu1) ...
Processing triggers for man-db (2.7.4-1) ...
Processing triggers for gnome-menus (3.13.3-6ubuntu1) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu3) ...
Processing triggers for bamfdaemon (0.5.2~bzr0+15.10.20150627.1-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for mime-support (3.58ubuntu1) ...
Setting up cups (2.1.0-4ubuntu3) ...
dpkg: error processing package cups (--configure):
subprocess installed post-installation script returned error exit status 1
Setting up grub-pc (2.02~beta2-29ubuntu0.3) ...
dpkg: error processing package grub-pc (--configure):
Setting up unattended-upgrades (0.86.2ubuntu1.1) ...
dpkg: error processing package unattended-upgrades (--configure):
dpkg: dependency problems prevent configuration of python3-software-properties:
python3-software-properties depends on unattended-upgrades; however:
Package unattended-upgrades is not configured yet.
dpkg: error processing package python3-software-properties (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of software-properties-common:
software-properties-common depends on python3-software-properties (= 0.96.13.1); however:
Package python3-software-properties is not configured yet.
dpkg: error processing package software-properties-common (--configure):
dpkg: dependency problems prevent configuration of software-properties-gtk:
software-properties-gtk depends on python3-software-properties (= 0.96.13.1); however:
software-properties-gtk depends on software-properties-common; however:
Package software-properties-common is not configured yet.
dpkg: error processing package software-properties-gtk No apport report written because MaxReports is reached already
(--configure):
Setting up synaptic (0.81.4build2) ...
cups
grub-pc
unattended-upgrades
Error in function:
dpkg: error processing package software-properties-gtk (--configure):
Before anyone marks this as duplicate, I tried searching for some fixes, and one said to delete some files in some system path and then sudo update, but they were read-only files. Then there was a solution that wanted me to install something through the sudo apt-get install command, but no matter what package/app i tried to install, the end line would always say this:
I just gave up after looking at a few fixes that had some crap I didn't understand at all. I have barely any knowledge on Ubuntu, and I haven't touched Ubuntu in 2-3 years
