  libc6-dbg : Depends: libc6 (= 2.31-0ubuntu9.9) but  2.31-0ubuntu9.2 is installed
 libc6-dev : Depends: libc6 (= 2.31-0ubuntu9.9) but 2.31-0ubuntu9.2 is installed
 libpam-modules : PreDepends: libpam-modules-bin (= 1.3.1-5ubuntu4.2)
              Recommends: update-motd but it is not installed
   mysql-server-8.0 : Depends: mysql-server-core-8.0 (=   8.0.26-0ubuntu0.20.04.2)
   but 8.0.29-0ubuntu0.20.04.3 is installed
   E: Unmet dependencies.
   Try 'apt --fix-broken install' with no packages (or specify a solution).
Then tried to run apt --fix-broken install and ran into error again.
   The following packages were automatically installed and are no longer required:
   libfwupdplugin1 libgupnp-av-1.0-2 libgupnp-dlna-2.0-3 linux-headers-5.4.0-73
   linux-headers-5.4.0-73-generic linux-image-5.4.0-73-generic
   linux-modules-5.4.0-73-generic linux-modules-extra-5.4.0-73-generic
   Use 'sudo apt autoremove' to remove them.
   The following additional packages will be installed:
   libc6 libc6:i386 libpam-modules mysql-server-8.0 virtualbox-dkms
   Suggested packages:
    glibc-doc glibc-doc:i386 locales:i386 mailx tinyca
   Recommended packages:
   update-motd virtualbox
   The following packages will be upgraded:
  5 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
  278 not fully installed or removed.
  Need to get 0 B/7,529 kB of archives.
  After this operation, 46.1 kB disk space will be freed.
  Do you want to continue? [Y/n] Y
  debconf: DbDriver "config": /var/cache/debconf/config.dat is  locked by another process: Resource temporarily unavailable
  (Reading database ... 475599 files and directories currently     installed.)
   Preparing to unpack .../libc6_2.31-0ubuntu9.9_amd64.deb ...
   De-configuring libc6:i386 (2.31-0ubuntu9.2) ...
   dpkg: error processing archive /var/cache/apt/archives /libc6_2.31-0ubuntu9.9_amd
       64.deb (--unpack):
   new libc6:amd64 package pre-installation script subprocess       returned error exit
   status 1
   Preparing to unpack .../libc6_2.31-0ubuntu9.9_i386.deb ...
   De-configuring libc6:amd64 (2.31-0ubuntu9.2) ...
   dpkg: error processing archive /var/cache/apt/archives/libc6_2.31-0ubuntu9.9_i38
   6.deb (--unpack):
   new libc6:i386 package pre-installation script subprocess returned error exit status 1
   /var/cache/apt/archives/libc6_2.31-0ubuntu9.9_amd64.deb
   /var/cache/apt/archives/libc6_2.31-0ubuntu9.9_i386.deb
Tried sudo apt autoremove
    Reading package lists... Done
    Building dependency tree
    You might want to run 'apt --fix-broken install' to correct these.
      mysql-server-8.0 : Depends: mysql-server-core-8.0 (=     8.0.26-0ubuntu0.20.04.2) but 8.0.29-0ubuntu0.20.04.3 is installed
      E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Got the same error so, tried running sudo dpkg --configure -a and got this
   dpkg: dependency problems prevent configuration of mysql-server-8.0:
    mysql-server-8.0 depends on mysql-server-core-8.0 (= 8.0.26-0ubuntu0.20.04.2);      however:
    Version of mysql-server-core-8.0 on system is 8.0.29-0ubuntu0.20.04.3.
dpkg: error processing package mysql-server-8.0 (--configure):
dependency problems - leaving unconfigured
Setting up linux-base (4.5ubuntu3.7) ... debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable dpkg: error processing package linux-base (--configure): installed linux-base package post-installation script subprocess returned error exit status 1 dpkg: dependency problems prevent configuration of initramfs-tools: initramfs-tools depends on linux-base; however: Package linux-base is not configured yet.
dpkg: error processing package initramfs-tools (--configure): dependency problems - leaving unconfigured Setting up cups-bsd (2.3.1-9ubuntu1.2) ... debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable dpkg: error processing package cups-bsd (--configure): installed cups-bsd package post-installation script subprocess returned error exit status 1 Setting up libssl1.1:amd64 (1.1.1f-1ubuntu2.13) ... debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable dpkg: error processing package libssl1.1:amd64 (--configure): installed libssl1.1:amd64 package post-installation script subprocess returned error exit status 1 Setting up libssl1.1:i386 (1.1.1f-1ubuntu2.13) ... debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable dpkg: error processing package libssl1.1:i386 (--configure): installed libssl1.1:i386 package post-installation script subprocess returned error exit status 1 dpkg: dependency problems prevent configuration of libfreerdp2-2:amd64: libfreerdp2-2:amd64 depends on libssl1.1 (>= 1.1.0); however: Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package libfreerdp2-2:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libpython3.8-dbg:amd64: libpython3.8-dbg:amd64 depends on libssl1.1 (>= 1.1.1); however: Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package libpython3.8-dbg:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libsasl2-modules:amd64: libsasl2-modules:amd64 depends on libssl1.1 (>= 1.1.0); however: Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package libsasl2-modules:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libsasl2-modules:i386: libsasl2-modules:i386 depends on libssl1.1 (>= 1.1.0); however: Package libssl1.1:i386 is not configured yet.
dpkg: error processing package libsasl2-modules:i386 (--configure): dependency problems - leaving unconfigured Setting up rsyslog (8.2001.0-1ubuntu1.3) ... The user syslog' is already a member ofadm'. The user syslog' is already a member oftty'. debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable dpkg: error processing package rsyslog (--configure): installed rsyslog package post-installation script subprocess returned error exit status 1 Setting up ufw (0.36-6ubuntu1) ... debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable dpkg: error processing package ufw (--configure): installed ufw package post-installation script subprocess returned error exit status 1 dpkg: dependency problems prevent configuration of php7.4-cli: php7.4-cli depends on libssl1.1 (>= 1.1.0); however: Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package php7.4-cli (--configure): dependency problems - leaving unconfigured Setting up samba-common (2:4.13.17~dfsg-0ubuntu0.21.04.2) ... debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable dpkg: error processing package samba-common (--configure): installed samba-common package post-installation script subprocess returned error exit status 1 dpkg: dependency problems prevent configuration of kmod: kmod depends on libssl1.1 (>= 1.1.0); however: Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package kmod (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of apache2-bin: apache2-bin depends on libssl1.1 (>= 1.1.1); however: Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package apache2-bin (--configure): dependency problems - leaving unconfigured Setting up locales (2.31-0ubuntu9.9) ... debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable dpkg: error processing package locales (--configure): installed locales package post-installation script subprocess returned error exit status 1 dpkg: dependency problems prevent configuration of libwinpr2-2:amd64: libwinpr2-2:amd64 depends on libssl1.1 (>= 1.1.0); however: Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package libwinpr2-2:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libqt5network5:amd64: libqt5network5:amd64 depends on libssl1.1; however: Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package libqt5network5:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libc6-dbg:amd64: libc6-dbg:amd64 depends on libc6 (= 2.31-0ubuntu9.9); however: Version of libc6:amd64 on system is 2.31-0ubuntu9.2.
dpkg: error processing package libc6-dbg:amd64 (--configure): dependency problems - leaving unconfigured Setting up tzdata (2022a-0ubuntu0.20.04) ... debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable dpkg: error processing package tzdata (--configure): installed tzdata package post-installation script subprocess returned error exit status 1 dpkg: dependency problems prevent configuration of libreoffice-l10n-en-gb: libreoffice-l10n-en-gb depends on locales | locales-all; however: Package locales is not configured yet. Package locales-all is not installed.
dpkg: error processing package libreoffice-l10n-en-gb (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of bluez: bluez depends on kmod; however: Package kmod is not configured yet.
dpkg: error processing package bluez (--configure): dependency problems - leaving unconfigured Setting up libpam0g:amd64 (1.3.1-5ubuntu4.3) ... debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable dpkg: error processing package libpam0g:amd64 (--configure): installed libpam0g:amd64 package post-installation script subprocess returned error exit status 1 dpkg: dependency problems prevent configuration of cups-daemon: cups-daemon depends on libpam0g (>= 0.99.7.1); however: Package libpam0g:amd64 is not configured yet.
dpkg: error processing package cups-daemon (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libssl-dev:amd64: libssl-dev:amd64 depends on libssl1.1 (= 1.1.1f-1ubuntu2.13); however: Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package libssl-dev:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of util-linux: util-linux depends on libpam0g (>= 0.99.7.1); however: Package libpam0g:amd64 is not configured yet.
dpkg: error processing package util-linux (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of pulseaudio-module-bluetooth: pulseaudio-module-bluetooth depends on bluez (>= 5.23); however: Package bluez is not configured yet.
dpkg: error processing package pulseaudio-module-bluetooth (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of samba-common-bin: samba-common-bin depends on samba-common (= 2:4.13.17~dfsg-0ubuntu0.21.04.2); however: Package samba-common is not configured yet.
dpkg: error processing package samba-common-bin (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of passwd: passwd depends on libpam0g (>= 0.99.7.1); however: Package libpam0g:amd64 is not configured yet.
dpkg: error processing package passwd (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of mount: mount depends on util-linux (>= 2.30.1-0ubuntu4~); however: Package util-linux is not configured yet.
dpkg: error processing package mount (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libpam-systemd:amd64: libpam-systemd:amd64 depends on libpam0g (>= 0.99.7.1); however: Package libpam0g:amd64 is not configured yet.
dpkg: error processing package libpam-systemd:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libcurl4:amd64: libcurl4:amd64 depends on libssl1.1 (>= 1.1.1); however: Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package libcurl4:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libc6-dev:amd64: libc6-dev:amd64 depends on libc6 (= 2.31-0ubuntu9.9); however: Version of libc6:amd64 on system is 2.31-0ubuntu9.2.
dpkg: error processing package libc6-dev:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libcryptsetup12:amd64: libcryptsetup12:amd64 depends on libssl1.1 (>= 1.1.0); however: Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package libcryptsetup12:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of language-pack-gnome-en-base: language-pack-gnome-en-base depends on locales (>= 2.3.6); however: Package locales is not configured yet.
dpkg: error processing package language-pack-gnome-en-base (--configure): dependency problems - leaving unconfigured Setting up ubuntu-advantage-tools (27.8~20.04.1) ... debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable dpkg: error processing package ubuntu-advantage-tools (--configure): installed ubuntu-advantage-tools package post-installation script subprocess returned error exit status 1 dpkg: dependency problems prevent configuration of bind9-dnsutils: bind9-dnsutils depends on libssl1.1 (>= 1.1.0); however: Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package bind9-dnsutils (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of sbsigntool: sbsigntool depends on libssl1.1 (>= 1.1.0); however: Package libssl1.1:amd64 is not configured yet.
dpkg: error processing package sbsigntool (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of initramfs-tools-core: initramfs-tools-core depends on kmod; however: Package kmod is not configured yet.
dpkg: error processing package initramfs-tools-core (--configure):
dpkg: error processing package virtualbox-dkms (--configure):
package is in a very bad inconsistent state; you should
reinstall it before attempting configuration
dpkg: dependency problems prevent configuration of bind9-host:
bind9-host depends on libssl1.1 (>= 1.1.0); however:
dpkg: error processing package bind9-host (--configure):
dpkg: dependency problems prevent configuration of openssl:
openssl depends on libssl1.1 (>= 1.1.1); however:
dpkg: error processing package openssl (--configure):
 Setting up xserver-xorg-legacy (2:1.20.13-1ubuntu1~20.04.2) ...
dpkg: error processing package xserver-xorg-legacy (--configure):
installed xserver-xorg-legacy package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of libicu-dev:amd64:
libicu-dev:amd64 depends on libc6-dev | libc-dev; however:
Package libc6-dev:amd64 is not configured yet.
Package libc-dev is not installed.
Package libc6-dev:amd64 which provides libc-dev is not configured yet.
dpkg: error processing package libicu-dev:amd64 (--configure):
Setting up libpam-runtime (1.3.1-5ubuntu4.3) ...
dpkg: error processing package libpam-runtime (--configure):
installed libpam-runtime package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of policykit-1:
policykit-1 depends on libpam-systemd; however:
Package libpam-systemd:amd64 is not configured yet.
policykit-1 depends on libpam0g (>= 0.99.7.1); however:
dpkg: error processing package policykit-1 (--configure):
dpkg: dependency problems prevent configuration of libmount-dev:amd64:
libmount-dev:amd64 depends on libc6-dev | libc-dev; however:
dpkg: error processing package libmount-dev:amd64 (--configure):
dpkg: dependency problems prevent configuration of libfreerdp-client2-2:amd64:
libfreerdp-client2-2:amd64 depends on libfreerdp2-2 (>= 2.1.0+dfsg1); however:
Package libfreerdp2-2:amd64 is not configured yet.
libfreerdp-client2-2:amd64 depends on libwinpr2-2 (>= 2.1.0+dfsg1); however:
Package libwinpr2-2:amd64 is not configured yet.
dpkg: error processing package libfreerdp-client2-2:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkmod2:amd64:
libkmod2:amd64 depends on libssl1.1 (>= 1.1.0); however:
dpkg: error processing package libkmod2:amd64 (--configure):
dpkg: too many errors, stopping
Processing triggers for libc-bin (2.31-0ubuntu9.9) ...
mysql-server-8.0
linux-base
initramfs-tools
cups-bsd
libssl1.1:amd64
libssl1.1:i386
libfreerdp2-2:amd64
rsyslog
ufw
php7.4-cli
samba-common
kmod
apache2-bin
locales
libwinpr2-2:amd64
libc6-dbg:amd64
tzdata
bluez
libpam0g:amd64
cups-daemon
libssl-dev:amd64
util-linux
samba-common-bin
passwd
mount
libcurl4:amd64
libc6-dev:amd64
bind9-dnsutils
sbsigntool
virtualbox-dkms
bind9-host
openssl
xserver-xorg-legacy
libicu-dev:amd64
libpam-runtime
policykit-1
libmount-dev:amd64
libkmod2:amd64
 Processing was halted because there were too many errors.
karel
  • 122,292
  • 133
  • 301
  • 332
user529674
