Ubuntu 17.10
I did a sudo apt-get upgrade. then I tried install software-properties-common the next thing was that mysql-server-5.7 was making errors, so I tried to reinstall it, and now everything I'm trying to do has errors like:
root@rtcserver:~# apt install software-properties-common
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
 libc-dev-bin : Depends: libc6 (> 2.27) but 2.26-0ubuntu2.1 is to be installed
 libc6-dev : Depends: libc6 (= 2.27-3ubuntu1) but 2.26-0ubuntu2.1 is to be installed
 libnss3 : Depends: libnspr4 (>= 2:4.12) but it is not going to be installed
 librados2 : Depends: libnspr4 (>= 2:4.9-2~) but it is not going to be installed
 software-properties-common : Depends: python3-software-properties (= 0.96.24.32.1) but 0.96.24.17 is to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
when I run dpkg --configure -a
root@rtcserver:~# dpkg --configure -aProcessing triggers for libc-bin (2.26-0ubuntu2.1) ...
Setting up mssql-server (14.0.3023.8-5) ...
locale: Cannot set LC_ALL to default locale: No such file or directory
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
dpkg: error processing package mssql-server (--configure):
 subprocess installed post-installation script returned error exit status 1
Setting up unattended-upgrades (0.98ubuntu1.1) ...
dpkg: error processing package unattended-upgrades (--configure):
Setting up libpam0g:amd64 (1.1.8-3.2ubuntu3.1) ...
dpkg: error processing package libpam0g:amd64 (--configure):
dpkg: dependency problems prevent configuration of libpam-systemd:amd64:
 libpam-systemd:amd64 depends on libpam0g (>= 0.99.7.1); however:
  Package libpam0g:amd64 is not configured yet.
dpkg: error processing package libpam-systemd:amd64 (--configure):
 dependency problems - leaving unconfigured
 mssql-server
 unattended-upgrades
 libpam0g:amd64
and when I try to dpkg -r --force-remove-reinstreq libc-dev-bin libc6-dev libnss3 librados2
root@rtcserver:~# dpkg -r --force-remove-reinstreq libc-dev-bin libc6-dev libnss3 librados2
dpkg: dependency problems prevent removal of libc6-dev:amd64:
 zlib1g-dev:amd64 depends on libc6-dev | libc-dev; however:
  Package libc6-dev:amd64 is to be removed.
  Package libc-dev is not installed.
  Package libc6-dev:amd64 which provides libc-dev is to be removed.
 libexpat1-dev:amd64 depends on libc6-dev | libc-dev; however:
 libstdc++-7-dev:amd64 depends on libc6-dev (>= 2.13-0ubuntu6).
 build-essential depends on libc6-dev | libc-dev; however:
 libpcre3-dev:amd64 depends on libc6-dev.
 libtool depends on libc6-dev | libc-dev; however:
dpkg: error processing package libc6-dev:amd64 (--remove):
 dependency problems - not removing
dpkg: dependency problems prevent removal of libnss3:amd64:
 openjdk-8-jre-headless:amd64 depends on libnss3 (>= 2:3.17.1).
 liboauth0:amd64 depends on libnss3 (>= 2:3.13.4-2~).
 ca-certificates-java depends on libnss3 (>= 3.12.9+ckbi-1.82-0ubuntu3~).
dpkg: error processing package libnss3:amd64 (--remove):
dpkg: dependency problems prevent removal of librados2:
 libcephfs2 depends on librados2 (>= 12.0.3).
dpkg: error processing package librados2 (--remove):
dpkg: dependency problems prevent removal of libc-dev-bin:
 libc6-dev:amd64 depends on libc-dev-bin (= 2.27-3ubuntu1); however:
  Package libc-dev-bin is to be removed.
dpkg: error processing package libc-dev-bin (--remove):
 libc6-dev:amd64
 libnss3:amd64
 librados2
 libc-dev-bin
when I try apt --fix-broken install
perl: warning: Falling back to a fallback locale ("C.UTF-8").
(Reading database ... 127695 files and directories currently installed.)
Preparing to unpack .../libc6_2.27-3ubuntu1_amd64.deb ...
dpkg: error processing archive /var/cache/apt/archives/libc6_2.27-3ubuntu1_amd64.deb (--unpack):
 subprocess new pre-installation script returned error exit status 1
The thing is I have unmet dependencies, which I cannot install, and they seems to be needed for every install I make. Is there any way to fix this?
This is also a remote server which I don't have access to reboot.
EDIT: it's seems i'm using Ubuntu 17.10 and not 17.04
Hee Jin
  • 886
For some reason, this worked:
sudo rm /var/cache/debconf/*.dat
as I have found in this post:
https://askubuntu.com/a/353423/826990
