I wanted to install python-pip so i ran sudo apt install python-pip and got this error
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libgcc1:i386 : Depends: libc6:i386 (>= 2.2.4) but it is not going to be installed
libgcrypt20:i386 : Depends: libc6:i386 (>= 2.28) but it is not going to be installed
libgpg-error0:i386 : Depends: libc6:i386 (>= 2.28) but it is not going to be installed
Recommends: libgpg-error-l10n:i386
libidn2-0:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
liblz4-1:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
liblzma5:i386 : Depends: libc6:i386 (>= 2.17) but it is not going to be installed
libunistring2:i386 : Depends: libc6:i386 (>= 2.7) but it is not going to be installed
python-pip : Depends: python-pip-whl (= 18.1-5) but it is not going to be installed
Recommends: python-all-dev (>= 2.6) but it is not going to be installed
Recommends: python-setuptools but it is not going to be installed
Recommends: python-wheel but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
it says Try "apt --fix-broken install" so I did that and got this
Correcting dependencies... Done
The following additional packages will be installed:
libc6:i386
Suggested packages:
glibc-doc:i386 locales:i386
The following NEW packages will be installed:
libc6:i386
0 upgraded, 1 newly installed, 0 to remove and 42 not upgraded.
88 not fully installed or removed.
Need to get 0 B/2578 kB of archives.
After this operation, 12.7 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
(Reading database ... 269716 files and directories currently installed.)
Preparing to unpack .../libc6_2.30-0ubuntu2.1_i386.deb ...
dpkg: error processing archive /var/cache/apt/archives/libc6_2.30-0ubuntu2.1_i386.deb (--unpack):
new libc6:i386 package pre-installation script subprocess returned error exit status 1
I tryied also running sudo apt-get install -f didn't work
So what shall I do? Ubuntu 19.10
