How can I run scripts automatically when Ubuntu starts up so I don't have to run them manually after startup?
Depending on what sort of scripts you need to run.. For services and the like you should use upstart. But for a user script these should be launched as session scripts by gnome! Have a look under System > Preferences > Startup Applications.
On a side note if you need some scripts to be run on terminal login you can add them to the .bash_login file in your home directory.
For 14.04 and older
A simple command (one which doesn't need to remain running) could use an Upstart job like:
start on startup
task
exec /path/to/command
Save this in a .conf file in /etc/init (if you need it to run as root when the system boots up), or in ~/.config/upstart (if you need it
to run as your user when you log in).
- 14,913
You can add commands to /etc/rc.local:
sudo nano /etc/rc.local
This executes the commands as root.
To execute commands as a specific user, use sudo -i -u (-i to also run the login shell). For example, to establish a persistent SSH tunnel, where myhost is definde in johndoes ~/.ssh/config file:
sudo -i -u johndoe autossh -nNT -L 1234:localhost:1234 myhost
Note that if /etc/rc.local did not exist (as is the case on Ubuntu since 16.04), you need to add a shebang line at the top (e.g. #!/bin/bash), and ensure the file is executable:
sudo chmod a+x /etc/rc.local
- 207,228
- 2,871
For 15.04 and later:
To run a (short-lived)1 command at startup using systemd, you can use a systemd unit of type OneShot. For example, create /etc/systemd/system/foo.service containing:
[Unit]
Description=Job that runs your user script
[Service]
ExecStart=/some/command
Type=oneshot
RemainAfterExit=yes
[Install]
WantedBy=multi-user.target
Then run:
sudo systemctl daemon-reload
sudo systemctl enable foo.service
Essentially, this is just converting a typical Upstart job to a systemd one (see Systemd for Upstart users).
You can run multiple commands from the same service file, using multiple ExecStart lines:
[Service]
ExecStart=/another/command some args
ExecStart=-/a/third/command ignore failure
The command must always be given with the full path. If any command fails, the rest aren't run. A - before the path tells systemd to ignore a non-zero exit status (instead of considering it a failure).
Relevant:
For user sessions, you can create the systemd unit in ~/.config/systemd/user instead. This should work with 16.04 onwards, but not earlier releases of Ubuntu with systemd (since those still used Upstart for user sessions). User session units can be controlled with the same commands as with system services, but with the --user option added:
systemctl --user daemon-reload
systemctl --user status foo.service
Shell syntax
Note that, unlike Upstart, systemd doesn't run the Exec* commands through a shell. It performs some limited variable expansion and multiple command (separated by ;) itself, but that's about it as far as shell-like syntax goes. For anything more complicated, say redirection or pipes, wrap your command in sh -c '...' or bash -c '...'.
1As opposed to long-lived daemons.
There are different ways to automatically run commands:
The upstart system will execute all scripts from which it finds a configuration in directory
/etc/init. These scripts will run during system startup (or in response to certain events, e.g., a shutdown request) and so are the place to run commands that do not interact with the user; all servers are started using this mechanism.You can find a readable introduction to at: http://upstart.ubuntu.com/getting-started.html the man pages
man 5 initandman 8 initgive you the full details.A shell script named
.gnomercin your home directory is automatically sourced each time you log in to a GNOME session. You can put arbitrary commands in there; environment variables that you set in this script will be seen by any program that you run in your session.Note that the session does not start until the
.gnomercscript is finished; therefore, if you want to autostart some long-running program, you need to append&to the program invocation, in order to detach it from the running shell.The menu option System -> Preferences -> Startup Applications allows you to define what applications should be started when your graphical session starts (Ubuntu predefines quite some), and add or remove them to your taste. This has almost the same purpose and scope of the
.gnomercscript, except you don't need to knowshsyntax (but neither can you use anyshprogramming construct).
- 16,737
$HOME/.config/autostart contains the startup application list. .desktop files in this folder will be executed on startup. It may need executable permission (chmod +x startup.desktop).
Sample example for .desktop file:
[Desktop Entry]
Type=Application
Exec="</path/to/script>"
Hidden=false
NoDisplay=false
X-GNOME-Autostart-enabled=true
Name=Startup Script
Here "</path/to/script>" is replaced with path to your script.sh
If you place your script myscript in /usr/local/bin so that it can be executed directly by command, you can write myscript instead of "</path/to/script>".
Sample example of myscript.sh:
#!/bin/bash
<commands to be executed>
exit
Result:
.desktop file will be launched from $HOME/.config/autostart which execute script by Exec=
For simple things you can add a command in System->Preferences->Sessions pointing to the location of your script.
Alternatively you can add it to /etc/init.d/rc.local or make an upstart job if it's a more low level stuff.
Take a look at https://help.ubuntu.com/community/UbuntuBootupHowto for more info
- 2,762
cron answer implemented different from top voted
This answer still uses cron but uses a different method than the top voted answer. This works since Ubuntu 16.04 but probably supported much sooner. It's just that I started using cron to run jobs when computer boots up since 16.04.
When does cron run?
In comments someone asked "when do they run?". You can tell in syslog / journalctl:
$ journalctl -b | grep cron
Jan 02 16:54:40 alien cron[919]: (CRON) INFO (pidfile fd = 3)
Jan 02 16:54:40 alien cron[919]: (CRON) INFO (Running @reboot jobs)
Jan 02 16:54:40 alien systemd[1]: Started Run anacron jobs.
Jan 02 16:54:40 alien anacron[949]: Anacron 2.3 started on 2018-01-02
Jan 02 16:54:40 alien anacron[949]: Normal exit (0 jobs run)
Jan 02 16:54:40 alien CRON[952]: pam_unix(cron:session): session opened for user root by (uid=0)
Jan 02 16:54:40 alien CRON[954]: pam_unix(cron:session): session opened for user root by (uid=0)
Jan 02 16:54:40 alien CRON[951]: pam_unix(cron:session): session opened for user root by (uid=0)
Jan 02 16:54:40 alien CRON[950]: pam_unix(cron:session): session opened for user root by (uid=0)
Jan 02 16:54:40 alien CRON[985]: (root) CMD ( /usr/local/bin/cron-reboot-cycle-grub-background)
Jan 02 16:54:40 alien CRON[954]: pam_unix(cron:session): session closed for user root
Jan 02 16:54:40 alien cron[919]: sendmail: Cannot open smtp.gmail.com:587
Jan 02 16:54:40 alien CRON[952]: pam_unix(cron:session): session closed for user root
Jan 02 16:54:40 alien CRON[950]: pam_unix(cron:session): session closed for user root
One thing to note is cron can email you status of jobs run and @reboot jobs run so early network manager and email won't be running unless you put a sleep command into your script(s).
Where to put your scripts
Put your scripts in the directory /etc/cron.d:
$ ll /etc/cron.d
total 44
drwxr-xr-x 2 root root 4096 Nov 26 19:53 ./
drwxr-xr-x 139 root root 12288 Dec 31 13:58 ../
-rw-r--r-- 1 root root 244 Dec 28 2014 anacron
-rw-r--r-- 1 root root 148 Feb 18 2017 cycle-grub-background
-rw-r--r-- 1 root root 138 Mar 5 2017 display-auto-brightness
-rw-r--r-- 1 root root 460 Nov 26 19:53 nvidia-hdmi-sound
-rw-r--r-- 1 root root 102 Feb 9 2013 .placeholder
-rw-r--r-- 1 root root 224 Nov 19 2016 touch-vmlinuz
-rw-r--r-- 1 root root 700 Aug 5 11:15 turn-off-hyper-threading
What does a script look like?
Here are a couple of scripts I have setup to run each boot:
$ cat /etc/cron.d/cycle-grub-background
SHELL=/bin/sh
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
@reboot root /usr/local/bin/cron-reboot-cycle-grub-background
$ cat /etc/cron.d/touch-vmlinuz
SHELL=/bin/sh
@reboot root touch "/boot/vmlinuz-"uname -r
- 2,865
- 105,762
If you want your script to run before systemd right after kernel starts, AFAIK the way is adding init=/path/to/script to the kernel command line in /boot/grub/grub.cfg or more future proof make your own menu entry in /etc/grub.d/40_custom by copying a menu entry from /boot/grub/grub.cfg and making needed changes (and running update-grub after that for grub to add your custom file to /boot/grub/grub.cfg).
linux /boot/vmlinuz-5.4.0-26-generic ... ro quiet splash
change to
linux /boot/vmlinuz-5.4.0-26-generic ... ro quiet splash init=/path/to/script
Take care to properly put e.g. #!/bin/bash on the first line and exec /sbin/init (if /sbin/init exists on your system - on mine it points to systemd) at the end to avoid kernel panic.
- 241
Something from the current decade: Open menu => search for "Startup applications" => open and click "add". I won't explain what fields "name" and "comment" are meant for, but the "command" is either a path to your script, or so-called "one-liner".
Ubuntu's docs regarding "Startup Applications": https://help.ubuntu.com/stable/ubuntu-help/startup-applications.html.en
- 303
You should use upstart for this. Upstart is used for Ubuntu processes that are automatically started. It is an enhanced solution like the old System-V init.d scripts. It also allows you to put in prerequisites to the start of your script (i.e. do you need the network running? etc.)
- 29,406
