I want to use two schedulers since I have a two Disks set for my system due to a separate HOME disk. Meaning I have SDA and SDB
Doing echo noop /sys/block/sda/queue/scheduler says permission denied with SUDO
I tried the suggested solution but it doesn't work anymore
/etc/udev/rules.d/60-schedulers.rules
ACTION=="add|change", KERNEL=="sda", ATTR{queue/scheduler}="noop"
ACTION=="add|change", KERNEL=="nvme0n1", ATTR{queue/scheduler}="noop"
cat /sys/block/nvme0n1/queue/scheduler
[none] mq-deadline
The setting is to be system-wide
It could be like this
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash elevator:sda=noop elevator:nvme0n1=noop"
Is this the correct line or do I need a comma between the two disk parameters?
userDepth
  • 2,040
You should use udev rule for that.
ACTION=="add|change", KERNEL=="sda", ATTR{queue/scheduler}="deadline"
