What is the best place to add a mode with xrandr?
As of now, I added
xrandr --newmode "1344x744_60.00"   80.75  1344 1408 1544 1744  744 747 757 773 -hsync +vsync
xrandr --newmode "1344x768_60.00"   84.00  1344 1416 1552 1760  768 771 781 798 -hsync +vsync
xrandr --addmode DP-2 "1344x744_60.00"
xrandr --addmode DP-2 "1344x768_60.00"
to my ~/.bashrc, but this is obviously not the best place, as every time I launch a bash process it tries to add modes. So far, it only throws some errors (see below tl;dr), but it is harmless, I guess.
Perhaps .gnomerc is appropriate, although I guess if I start an xrdp session the mode may not be available.
Related:
  1. How to run scripts on start up?
  2. https://unix.stackexchange.com/questions/120291/how-to-get-external-monitor-resolution-set-by-xrandr-to-persist
EDIT: It seems ~/.xprofile may be a good place for these settings. I am not sure it works well with vino-server, which I need.
EDIT 2: This suggests using ~/.xinitrc. But it may be outdated.
TL;DR: Errors I get:
  1. When connecting from a text terminal (e.g., ssh)
       Can't open display
       Can't open display
       Can't open display
       Can't open display
  2. When starting a graphic terminal when the modes were already added
       X Error of failed request:  BadName (named color or font does not exist)
         Major opcode of failed request:  140 (RANDR)
         Minor opcode of failed request:  16 (RRCreateMode)
         Serial number of failed request:  27
         Current serial number in output stream:  27
If you are using X11, you can add the mode to a config file in /etc/X11/xorg.conf.d/. Name it something like 99-modes.conf.
Section "Modes"
   Identifier "modes"
   Modeline "1368x768"  85.86  1368 1440 1584 1800  768 769 772 795  -HSync +Vsync
EndSection
If the above doesn't work, you'll need to expand the config.
Section "Monitor"
   Identifier "monitor"
EndSection
Section "Device" Identifier "card" EndSection
Section "Screen" Identifier "screen" Device "card" Monitor "monitor" SubSection "Display" Modes "1368x768" EndSubSection EndSection
See also:
xiota
  • 5,038
