I need to run the command
source "/opt/sqlanywhere17/bin64/sa_config.sh" after Ubuntu starts. It's taken from here. It updated LD_LIBRARY_PATH, PATH etc.
I tried this, but doesn't work. After system starts LD_LIBRARY_PATH is empty.
xralf
  • 75
Sourcing a command will affect your current shell environment. Running this from crontab wont work. Put it in your .bashrc instead. This is also what the tutorial says:
Add the below line in **.profile** or **.bashrc**
# Add the below line in **.profile** or **.bashrc**
## This will load all the needed environmental variables for SQLanywhere17
Run:
echo 'source "/opt/sqlanywhere17/bin64/sa_config.sh"' >> "~/.bashrc"
and restart your terminal.
pLumo
  • 27,991
