I would like to make a sudo command (sudo service smbd restart) run after 1 minute of being logged on. How would I go about doing this?
P.S. This is a system with no monitor, mouse, keyboard or speakers connected - it's a printer and file server.
landroni
  • 6,011
A) If it's at system start-up, add this to the end of your /etc/rc.local (1): (before the exit 0, obviously):
( sleep 60 && service smbd restart )&
Note:
  1. the outer () are needed so that the complex command detach itself and go to the background, allowing the boot process to finish;
  2. sudo is not needed there, /etc/rc.local is executed by root;
  3. Are you really sure this is a solution? It is a race condition asking to happen...
B) if it's at user login, you need two steps:
  1. configure your sudo so that it will not ask for a password for service smbd restart command (see How do I run specific sudo commands without a password?);
  2. prepare a script with the following contents and add it to your autorun/startup program (varies with the desktop environment you are using).
Script:
#!/bin/bash
Footnotes
(1) check if /etc/rc.local is executable. Otherwise, make it so with sudo chmod +x /etc/rc.local
Rmano
  • 32,167
Try man sleep:
sleep 60 && sudo service smbd restart
Put this in the autorun programs or scripts executed at login time.
landroni
  • 6,011
