-1
I have an application which I was running by using ./cmd from the directory where it is located. Now what I am looking for something by which the application starts automatically when my system boots up. I came across some suggestion saying write a script, do something in init.d, etc. But I am not able to reach a clear solution.
Request you kindly provide your valuable suggestion on same.
This answer might help you: https://askubuntu.com/a/816/278518
Don't forget to put the whole path in the crontab file. Meaning, after running crontab -e your editor opens with the crontab file so you can add a new line to it. On that line, if your script is let's say in
~/mycoolscript.sh
you have to write the new line in your crontab file as:
@reboot /bin/sh /home/_your_username_/mycoolscript.sh
since cron does not evaluate shortcut paths and also does not run shebang scripts.
Hope this helps.
alexandru
