The following python snippet should work for you:
#!/usr/bin/env python
import re
import sys
import urllib2
from gi.repository import Gtk, GLib
from gi.repository import AppIndicator3 as appindicator
class MyIndicator:
def __init__(self):
# Create Indicator with icon and label
icon_image = "/usr/share/unity/icons/panel-shadow.png"
self.ind = appindicator.Indicator.new(
"MagicNumber",
icon_image,
appindicator.IndicatorCategory.APPLICATION_STATUS
self.ind.set_status(appindicator.IndicatorStatus.ACTIVE)
self.menu_structure()
# Menu structure
def menu_structure(self):
# GTK menu
self.menu = Gtk.Menu()
self.exit = Gtk.MenuItem("Exit")
self.exit.connect("activate", self.quit)
self.exit.show()
self.menu.append(self.exit)
self.ind.set_menu(self.menu)
content = urllib2.urlopen('http://askubuntu.com/questions')
questions = re.search('<div class="summarycount al">(.*?)</div>', content.read())
self.ind.set_label(str(questions.group(1)), "")
GLib.timeout_add_seconds(2,self.menu_structure)
def quit(self, widget):
sys.exit(0)
if __name__ == "__main__":
indicator = MyIndicator()
Gtk.main()
Just replace the url, the 2 second delay and the re.search pattern for your needs.
re.search('(.*)', content.read()) should work if your file only contains the number.
The above code displays the total questions on Askubuntu in your taskbar:
Reference: https://unity.ubuntu.com/projects/appindicators/
