I have 5-inch a 800x480 tft connected to the LVDS connector on a Portwell WADE-8020 mini-ITX embedded system board. I would like to build a XMBC/Kodi box for streming my music from my freenas PC with the tft showing what is been played, I got as fare as this...
sudo xrandr --newmode "800x480_60.00"  29.50  800 824 896 992  480 483 493 500 -hsync +vsync`enter code here
then,
sudo xrandr --addmode LVDS1 800x480_60.00
now that I get the correct resolution, I now have a black band on the top of the screen.
sudo xrandr --output LVDS1 --set "scaling mode"  "Full aspect"
However this did not solve the issue, also I know I need to amend the /bin/sh file with this from googling so I don't need to keep doing this at every boot. But I don't know how to as I'm very new to Linux.
#!/bin/sh
pa4080
  • 30,621
Block
  • 33
Approach 1: Using Startup Applications
You could make an executable script file and add it to the list of Startup Applications. Here is a screenshot how the result of next steps looks in my system.
1. Create a directory where the script file will be contained. For example this directory could be placed into your home directory and could be named .autorun-startup:
mkdir ~/.autorun-startup
2. Create the script file and make it executable:
  • Let's call this file custom-screen-resolution.sh:
    nano ~/.autorun-startup/custom-screen-resolution.sh
    In this example is used Nano text editor (where you can use ctrl+o to save the edits and ctrl+x to exit), but you can use your favorite text editor.
  • The content of the script custom-screen-resolution.sh should look as this:
    #!/bin/sh
    # To calculate the modeline use: cvt 800 640 60
    # To view the available modes and the output names use: xrandr
    # Create new mode:
    # Add the new mode to the list of modes of certain output:
    # Set the new mode as current for the certain output:
    xrandr --output LVDS1 --mode 800x480_60.00
  • Set executable permissions to the file custom-screen-resolution.sh (or use Nautilus):
    chmod +x ~/.autorun-startup/custom-screen-resolution.sh
3. Open the application Startup Applications, click on the Add button to add a new entry and fill the parameters values:
Name:     Custom Screen Resolution
Command:  /home/<user>/.autorun-startup/custom-screen-resolution.sh
Comment:  Add Custom Screen Resolution
Save the entry and Close Startup Applications.
Approach 2: Using XDG Utils
  • This approach allows you to execute the above commands during system startup system wide (for all users). For this purpose you must create .desktop file and place it into a appropriate place, to be more specific, according to the example into the directory /etc/xdg/autostart/. I found this approach here, but there are also available and other ways how to use XDG Utils tools package.
1. Create a directory where the .desktop file will be contained:
sudo mkdir -p /etc/xdg/autostart
2. Create the .desktop file and make it executable:
  • Let's call this file custom-screen-resolution.desktop:
    sudo nano /etc/xdg/autostart/custom-screen-resolution.desktop
  • The content of the file custom-screen-resolution.desktop should look as:
    [Desktop Entry]
    Name=Custom Screen Resolution
    Exec=sh -c 'xrandr --newmode "800x480_60.00"  29.50  800 824 896 992  480 483 493 500 -hsync +vsync; xrandr --addmode LVDS1 800x480_60.00; xrandr --output LVDS1 --mode 800x480_60.00'
    Terminal=false
    Type=Application
    Categories=Application
    Make sure custom-screen-resolution.desktop has read permissions system wide.
  • Set executable permissions to the file custom-screen-resolution.desktop. In this case, this step is optional and you need it, if you want to test your file via 'double click'.
Note 1: The .desktop file could use the script created in the above approach. For this purpose change the Exec as follow (make sure custom-screen-resolution.sh has read permissions system wide):
Exec=/home/<user>/.autorun-startup/custom-screen-resolution.sh
Note 2: Create the .desktop file within the directory /home/<user>/.autorun-startup and then make a symbolic link to /etc/xdg/autostart:
sudo ln -s /home/<user>/.autorun-startup/custom-screen-resolution.desktop /etc/xdg/autostart/
Further reading
Add resolution:
Startup commands:
pa4080
  • 30,621
