As soon as I startup the terminal (Ubuntu 12.04 LTS), I get the error message:
bash: export: `/lib/perl5/site_perl/5.14.2/': not a valid identifier
I am not really familiar with Linux yet. How do I rectify this?
EDIT:
if [ -f /etc/bash_completion ] && ! shopt -oq posix; then
    . /etc/bash_completion
fi
export PATH=$PATH/usr/lib/lightdm/lightdm/usr/local/sbin/usr/local/bin/usr/sbin$
export PATH=/usr/lib/lightdm/lightdm/usr/local/sbin/usr/local/bin/usr/sbin/usr/$
export PATH=$PATH:/home/lib-11/Downloads/randfold-2.0/randfold
export PERL5LIB=PERL5LIB:/home/lib-11/Downloads/mirdeep2 /lib/perl5/site_perl/5$
export PATH=$PATH:/home/lib-11/Downloads/mirdeep2
mirdeep2 and randfold are executables that I wanted to run.
I guess it is because of the space in the line export PERL5LIB=PERL5LIB:/home/lib-11/Downloads/mirdeep2 /lib/perl5/site_perl/5$ (Notice the space between mirdeep2 and /lib/perl5)
It should be export PERL5LIB=PERL5LIB:/home/lib-11/Downloads/mirdeep2/lib/perl5/site_perl/5$ (Without space)
Camicri
  • 1,390
As you've already been told the main issue was the space in the variable's definition. However, your ~/.bashrc file has a few more issues. First of all, it is not the right place to define the PATH or PERL5LIB variables. These should instead be added to ~/.profile or, if the file exists, to ~/.bash_profile.
Also, all of the export lines can be combined into these two:
export "PATH=$PATH:/usr/lib/lightdm:/usr/local/sbin:usr/local/bin:/usr/sbin:/home/lib-11/Downloads/randfold-2.0/randfold:/home/lib-11/Downloads/mirdeep2"
export PERL5LIB="PERL5LIB:/home/lib-11/Downloads/mirdeep2/lib/perl5/site_perl/5"
terdon
  • 104,119
