How can I schedule a command to run the next time I log in? I don't want it to run every time, just once.
Asked
Active
Viewed 5,436 times
This is really "ugly" solution, but you can add classic logon/startup script and after first run remove this script automatically.
#!/bin/bash
your command &
rm /path/to/script/yourscript.sh
The script will be removed, so it can't be started again.
(I'm sure there's a bettter solution, but I don't know it.)
Vojtech Trefny
- 15,601
running a script has couple of options How to run scripts on start up?
I would try .gnomerc one, you can make it one time by making your script remove itself from .gnomerc once its done.
This is already covered on this very site : How to run scripts on start up?
The second answer down seems to be the cleanest solution.
