I use 17.04 and rc.local is gone(I couldn't do it with rc.local anyway).
I just want this two commands to run at the startup;
cd Folder
python3 file.py
That's it. I looked all the similar answers here but I couldn't make it.
Thank you so much!
Not using 17.04, but under 16.04 there is a "Startup and Shutdown" item in "System Settings". There is an "Autostart" item under there that allows you to specify scripts or programs that you want to run at startup.
You can use a cronjob.
Edit your cronjobs with crontab -e, and add the script to run
@reboot /home/user/script.sh as an example
It is best to use a full path to your script
