19
This question is ALL over ubuntu, with MODS saying its duplicate, but I have found no good answers!
I want to run the command, (this will work for script as well)
sudo service deluged restart
at boot after everything is done, IE: last thing to run
I first found this post, marked duplicate
Auto Run a command at startup
Which seth blocked from future help and linked to this post
Start Applications at startup
First off, I run a server, not a desktop (Which is what the linked "duplicate" guide shows you), so I can only use CLI based guides. Second those are 2 different questions.
Then there is this post
Marked as duplicate and linked to this question which may answer his specific question, but does not answer the question, run a command at boot.
Why isn't my upstart service starting on system boot?
Anyway, there is more!, but what I am getting at is I know what I want is just ONE example of how to do this via CLI and simple. I am not a coder, but I can read code and edit it to suit my needs and understand it, i just can't create it so to speak.
As another mod (takkat) has said, this is a duplicate of a question relating to
how to enable to disable services but again my point is that this post, i am using
as an example on how to run a command/script at boot, not troubleshooting why a service is not runnnig. While rc.local may serve as a dirty fix for a problem i have, deluge web-ui auto connect it can be used in a lot of other situations.
please try to answer the question directly, not give me links to what you think might help, and if it is a duplicate then link to a cli guide that covers HOW TO RUN A COMMAND/SCRIPT AT BOOT, because CLI guides can be used by both desktop and server users of Ubuntu.
FreeSoftwareServers
  • 1,129
  • 14
  • 32
rc.local has solved this for me, and although I have read is outdated But kept around for compatibility, if somebody has the updated, but JUST AS SIMPLE answer, please share as I will update my server.
sudo nano /etc/rc.local
You can use either calling a script in rc.local or directly run desired commands. Eg:
# By default this script does nothing.
/root/script.sh (or) sudo service deluged restart
exit 0
Cheers!
FreeSoftwareServers
  • 1,129
  • 14
  • 32
