128
I can't update my system because it freezes while installing a third-party update (zramswap-enabler)!
Sometimes I get the following message in Update manager:
Could not initialize the package information An unresolvable problem occurred while initializing the package information.
Please report this bug against the 'update-manager' package and include the following error message:
E:The package zramswap-enabler needs to be reinstalled, but I can't find an archive for it.
I tried to remove the zramswap-enabler, but it's impossible because I get the following message:
dpkg: error processing zramswap-enabler (--remove):
 Package is in a very bad inconsistent state - you should
 reinstall it before attempting a removal.
 zramswap-enabler
Actually I would really reinstall that package, but it is unable to do it! If I remove this third-party PPA then the system is warning me about a very very serious problem.
So why can I not install/reinstall/remove/update this package and why freezes the updater if I try to update?
8 Answers8
161
Edited out of the question and added as an answer.
  1. Make sure that your PPA is set up.
  2. Remove the broken package via the following command:
    sudo dpkg --remove --force-remove-reinstreq zramswap-enabler
  3. Install the package again:
    sudo apt-get install zramswap-enabler
  4. After restart (not necessary), you are able to install the updates correctly!
Actually you can fix any "Package is in a very bad inconsistent state” issues with this solution!
nanofarad
  • 20,906
106
This worked for me after pretty much scouring the whole of AskUbuntu and Ubuntu forums! (Source). I'm running Lubuntu 14.04
sudo mv /var/lib/dpkg/info/<packagename>.* /tmp/
sudo dpkg --remove --force-remove-reinstreq <packagename>
sudo apt-get remove <packagename>
sudo apt-get autoremove && sudo apt-get autoclean
Alvar
  • 17,038
26
I had a situation worse than this. I had to remove the half-installed packages by forcing dependencies.
sudo dpkg --remove --force-remove-reinstreq --force-depends <package-name>
Then I had to reinstall them
sudo apt-get -f install
That should solve any issue. But please make sure you have network connectivity when you try to do this. Otherwise, you will have to go through even more trouble.
The other answers are correct to mention a package removal followed by apt-get install -f to reinstall the broken package (and fully install other half-installed packages). However, this can be done in one step:
sudo apt-get install -f --reinstall zramswap-enabler
David Foerster
  • 36,890
  • 56
  • 97
  • 151
i'd try cleaning the status of my installation before resorting to uninstalling whatever created the problem:
apt-get autoclean
apt-get update
apt-get upgrade
apt-get install -f
much better way to solve this in most cases and in at least one instance had helped me when the other way wouldn't work (because huge dependencies on the package to be removed)
The same thing happened to me when I got disconnected from the internet while downloading the wireshark package. After that, when I tried to reinstall it, it threw the same error:
I've tried all the commands to install, purge, remove and reinstall but nothing worked.
After a little bit of googling, I stumbled upon this command:
sudo dpkg -i --force-overwrite /var/cache/apt/archives/libwireshark8_2.2.6+g32dac6a-2ubuntu0.16.04_amd64.deb
(changed libwireshark8_2.2.6+g32dac6a-2ubuntu0.16.04_amd64.deb with the package that was creating the problem in the directory /var/cache/apt/archives/).
After running this command all the issues were resolved. I removed the package again using:
sudo apt --purge remove libwireshark8:amd64
sudo apt autoremove to fully remove the package.
Then I installed wireshark again using:
sudo apt-get install wireshark
Everything works smoothly now!
References:
I had similar problem with quagga, the routing daemon. Just reinstaling the package worked for me:
# apt-get install -f
<some output ommited>
dpkg: warning: overriding problem because --force enabled:
wget http://security.debian.org/debian-security/pool/updates/main/q/quagga/quagga_0.99.22.4-1+wheezy3_i386.deb
dpkg -i quagga_0.99.22.4-1+wheezy3_i386.deb
Now its ok again:
#apt-get install -f
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
locutus
I used this to fix this same issue:
apt reinstall [package]
Zeki
  • 99
