I tried to install python 2.7.3 from python 2.7.13 and then I got a problem with debconf everytime I try to upgrade or install something, this always show up :
dpkg: error processing package debconf (--configure):
package is in a very bad inconsistent state; you should
reinstall it before attempting configuration
debconf
Help me please guys
apt-get upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
aapt clang curl graphviz gstreamer1.0-plugins-bad ipython king-phisher
libcurl3 libcurl3-gnutls libfbclient2 libgeos-c1v5 libgspell-1-1
libgstreamer-plugins-bad1.0-0 libkpathsea6 libnma-common libnma0
libosinfo-1.0-0 libpoppler-glib8 libptexenc1 libradare2-dev libsynctex1
libtexlua52 libtexluajit2 linux-image-amd64 mesa-utils mitmproxy mpg123
nautilus nautilus-data network-manager-gnome poppler-utils postgresql
python-html5lib python-matplotlib python-pycurl python-twisted
python-twisted-core python-twisted-web python-wheel python-yara
python3-louis radare2 reportbug rsyslog sparta speech-dispatcher
speech-dispatcher-audio-plugins texlive-base texlive-binaries
texlive-latex-base tightvncserver vim vim-common vim-gtk vim-gui-common
vim-runtime vim-tiny xpdf xtightvncviewer zeitgeist-core
0 upgraded, 0 newly installed, 0 to remove and 60 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up debconf (1.5.60) ...
Traceback (most recent call last):
File "/usr/lib/python2.7/site.py", line 563, in <module>
main()
File "/usr/lib/python2.7/site.py", line 545, in main
known_paths = addusersitepackages(known_paths)
File "/usr/lib/python2.7/site.py", line 278, in addusersitepackages
user_site = getusersitepackages()
File "/usr/lib/python2.7/site.py", line 253, in getusersitepackages
user_base = getuserbase() # this will also set USER_BASE
File "/usr/lib/python2.7/site.py", line 243, in getuserbase
USER_BASE = get_config_var('userbase')
File "/usr/lib/python2.7/sysconfig.py", line 521, in get_config_var
return get_config_vars().get(name)
File "/usr/lib/python2.7/sysconfig.py", line 420, in get_config_vars
_init_posix(_CONFIG_VARS)
File "/usr/lib/python2.7/sysconfig.py", line 288, in _init_posix
raise IOError(msg)
IOError: invalid Python installation: unable to open /usr/lib/python2.7/config/Makefile (No such file or directory)
subprocess installed post-installation script returned error exit status 1
debconf
sudo apt install -f
main()
raise IOError(msg)
debconf
sudo apt dist-upgrade
The following packages were automatically installed and are no longer required:
espeak-data firebird2.5-common firebird2.5-common-doc libchromaprint0
libespeak1 libgeos-3.5.0 libglew1.13 liblouis10 libmimic0
libopencv-contrib2.4v5 libopencv-legacy2.4v5 libopencv-ml2.4v5 libosinfo-db
libperl5.22 libpoppler61 libradare2-0.9.9 libschroedinger-1.0-0 libwildmidi1
libx265-79
Use 'sudo apt autoremove' to remove them.
The following NEW packages will be installed:
clang-3.8 espeak-ng-data firebird3.0-common firebird3.0-common-doc libann0
libclang-common-3.8-dev libclang1-3.8 libespeak-ng1 libfastjson4
libfltk-images1.3 libfltk1.3 libgeos-3.5.1 libglew2.0 libgnome-autoar-0-0
libgnome-autoar-common libgspell-1-common libidn2-0 libjansson4 libjsoncpp1
liblilv-0-0 libllvm3.8 liblognorm5 liblouis12 libobjc-6-dev libout123-0
libpcaudio0 libpoppler64 libprotobuf-lite10 libradare2-1.1 libserd-0-0
libsord-0-0 libsratom-0-0 libtommath1 libwildmidi2 libxapian30 libyara3
linux-image-4.9.0-kali1-amd64 llvm-3.8 llvm-3.8-dev llvm-3.8-runtime
osinfo-db postgresql-9.6 postgresql-client-9.6 postgresql-contrib-9.6
python-backports-shutil-get-terminal-size python-brotlipy python-constantly
python-cssutils python-functools32 python-incremental python-ipython
python-ipython-genutils python-jsbeautifier python-keyring
python-keyrings.alt python-pathlib2 python-pickleshare python-pluginbase
python-prompt-toolkit python-secretstorage python-subprocess32
python-traitlets python-typing python-wcwidth python-webencodings
python3-debianbts python3-httplib2 python3-pysimplesoap python3-reportbug
speech-dispatcher-espeak-ng tigervnc-common tigervnc-standalone-server
tigervnc-viewer xsltproc xxd
The following packages will be upgraded:
60 upgraded, 75 newly installed, 0 to remove and 0 not upgraded.
Need to get 166 MB of archives.
After this operation, 546 MB of additional disk space will be used.
Get:1 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libxapian30 amd64 1.4.2-1 [1,064 kB]
Get:2 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libfastjson4 amd64 0.99.4-1 [22.7 kB]
Get:3 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 liblognorm5 amd64 2.0.1-1.1 [57.3 kB]
Get:4 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 rsyslog amd64 8.24.0-1 [553 kB]
Get:5 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 vim-gtk amd64 2:8.0.0197-1 [1,263 kB]
Get:6 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 vim amd64 2:8.0.0197-1 [1,033 kB]
Get:7 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 vim-tiny amd64 2:8.0.0197-1 [446 kB]
Get:8 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 vim-runtime all 2:8.0.0197-1 [5,408 kB]
Get:9 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 vim-common all 2:8.0.0197-1 [158 kB]
Get:10 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 vim-gui-common all 2:8.0.0197-1 [159 kB]
Get:11 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 xxd amd64 2:8.0.0197-1 [131 kB]
Get:12 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python3-httplib2 all 0.9.2+dfsg-1 [33.6 kB]
Get:13 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python3-pysimplesoap all 1.16-2 [38.4 kB]
Get:14 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python3-debianbts all 2.6.1 [11.3 kB]
Get:15 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python3-reportbug all 7.1.2 [126 kB]
Get:16 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 reportbug all 7.1.2 [126 kB]
Get:17 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libllvm3.8 amd64 1:3.8.1-17 [10.4 MB]
Get:18 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libclang1-3.8 amd64 1:3.8.1-17 [4,187 kB]
Get:19 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libobjc-6-dev amd64 6.3.0-5 [198 kB]
Get:20 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libclang-common-3.8-dev amd64 1:3.8.1-17 [2,197 kB]
Get:21 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 clang-3.8 amd64 1:3.8.1-17 [22.8 MB]
Get:22 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 clang amd64 1:3.8-34+b1 [5,894 B]
Get:23 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libidn2-0 amd64 0.16-1 [60.6 kB]
Get:24 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libcurl3 amd64 7.52.1-1 [290 kB]
Get:25 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 curl amd64 7.52.1-1 [227 kB]
Get:26 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 espeak-ng-data amd64 1.49.0+dfsg-7 [2,463 kB]
Get:27 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 firebird3.0-common-doc all 3.0.1.32609.ds4-13 [36.2 kB]
Get:28 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 firebird3.0-common all 3.0.1.32609.ds4-13 [13.7 kB]
Get:29 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libann0 amd64 1.1.2+doc-6 [24.9 kB]
Get:30 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 graphviz amd64 2.38.0-16 [798 kB]
Get:31 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-pathlib2 all 2.2.0+really2.1.0-1 [16.5 kB]
Get:32 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-pickleshare all 0.7.4-1 [6,736 B]
Get:33 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-wcwidth all 0.1.7+dfsg1-1 [14.6 kB]
Get:34 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-prompt-toolkit all 1.0.9-1 [174 kB]
Get:35 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-ipython-genutils all 0.1.0-2 [20.7 kB]
Get:36 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-traitlets all 4.3.1-1 [60.6 kB]
Get:37 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-backports-shutil-get-terminal-size all 1.0.0-3 [4,656 B]
Get:38 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 ipython all 5.1.0-3 [5,496 B]
Get:39 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-ipython all 5.1.0-3 [375 kB]
Get:40 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-functools32 all 3.2.3.2-3 [11.0 kB]
Get:41 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-subprocess32 amd64 3.2.7-2 [28.9 kB]
Get:42 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-matplotlib amd64 2.0.0-3 [1,596 kB]
Get:43 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-pluginbase all 0.4-0kali1 [7,708 B]
Get:44 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 postgresql-client-9.6 amd64 9.6.1-2 [1,208 kB]
Get:45 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 postgresql-9.6 amd64 9.6.1-2 [4,016 kB]
Get:46 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 postgresql all 9.6+178 [55.1 kB]
Get:47 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 king-phisher all 1.4.0-0kali1 [224 kB]
Get:48 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libcurl3-gnutls amd64 7.52.1-1 [288 kB]
Get:49 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libpcaudio0 amd64 1.0-1 [6,798 B]
Get:50 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libespeak-ng1 amd64 1.49.0+dfsg-7 [167 kB]
Get:51 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libtommath1 amd64 1.0-4 [56.0 kB]
Get:52 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libfbclient2 amd64 3.0.1.32609.ds4-13 [504 kB]
Get:53 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libfltk1.3 amd64 1.3.3-8+b1 [523 kB]
Get:54 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libfltk-images1.3 amd64 1.3.3-8+b1 [52.6 kB]
Get:55 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libgeos-3.5.1 amd64 3.5.1-3 [611 kB]
Get:56 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libgeos-c1v5 amd64 3.5.1-3 [187 kB]
Get:57 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libglew2.0 amd64 2.0.0-3 [143 kB]
Get:58 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libgnome-autoar-common all 0.1.1-4 [3,152 B]
Get:59 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libgnome-autoar-0-0 amd64 0.1.1-4+b1 [24.2 kB]
Get:60 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libgspell-1-common all 1.2.2-1 [24.9 kB]
Get:61 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libgspell-1-1 amd64 1.2.2-1 [42.5 kB]
Get:62 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libjansson4 amd64 2.9-1 [28.1 kB]
Get:63 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libkpathsea6 amd64 2016.20160513.41080.dfsg-1 [159 kB]
Get:64 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 texlive-binaries amd64 2016.20160513.41080.dfsg-1 [7,389 kB]
Get:65 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libptexenc1 amd64 2016.20160513.41080.dfsg-1 [57.8 kB]
Get:66 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libsynctex1 amd64 2016.20160513.41080.dfsg-1 [64.7 kB]
Get:67 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libtexlua52 amd64 2016.20160513.41080.dfsg-1 [111 kB]
Get:68 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libtexluajit2 amd64 2016.20160513.41080.dfsg-1 [249 kB]
Get:69 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libpoppler64 amd64 0.48.0-2 [1,285 kB]
Get:70 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libserd-0-0 amd64 0.26.0~dfsg0-1 [45.3 kB]
Get:71 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libsord-0-0 amd64 0.16.0~dfsg0-1 [22.7 kB]
Get:72 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libsratom-0-0 amd64 0.6.0~dfsg0-1 [16.6 kB]
Get:73 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 liblilv-0-0 amd64 0.24.2~dfsg0-1 [42.7 kB]
Get:74 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 network-manager-gnome amd64 1.4.2-1 [970 kB]
Get:75 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libnma0 amd64 1.4.2-1 [122 kB]
Get:76 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libnma-common all 1.4.2-1 [60.3 kB]
Get:77 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libout123-0 amd64 1.23.8-1 [37.7 kB]
Get:78 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libpoppler-glib8 amd64 0.48.0-2 [122 kB]
Get:79 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libprotobuf-lite10 amd64 3.0.0-9 [125 kB]
Get:80 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libwildmidi2 amd64 0.4.0-2 [60.9 kB]
Get:81 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libyara3 amd64 3.5.0+dfsg-8 [102 kB]
Get:82 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 linux-image-4.9.0-kali1-amd64 amd64 4.9.6-3kali2 [37.9 MB]
Get:83 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 linux-image-amd64 amd64 4.9+78+kali1 [7,246 B]
Get:84 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 llvm-3.8-runtime amd64 1:3.8.1-17 [87.2 kB]
Get:85 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 llvm-3.8 amd64 1:3.8.1-17 [1,547 kB]
Get:86 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libjsoncpp1 amd64 1.7.4-3 [75.6 kB]
Get:87 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 llvm-3.8-dev amd64 1:3.8.1-17 [16.1 MB]
Get:88 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 mesa-utils amd64 8.3.0-3 [32.7 kB]
Get:89 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-brotlipy amd64 0.6-0kali1 [281 kB]
Get:90 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-cssutils all 1.0-4.1 [204 kB]
Get:91 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-jsbeautifier all 1.6.4-6 [45.5 kB]
Get:92 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-typing all 3.5.2.2-1 [19.1 kB]
Get:93 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 mitmproxy all 0.18.2-6kali1 [1,079 kB]
Get:94 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 mpg123 amd64 1.23.8-1 [167 kB]
Get:95 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 nautilus amd64 3.22.2-1 [746 kB]
Get:96 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 nautilus-data all 3.22.2-1 [1,701 kB]
Get:97 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 osinfo-db all 0.20160728+git20161020-1 [61.2 kB]
Get:98 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 poppler-utils amd64 0.48.0-2 [151 kB]
Get:99 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 postgresql-contrib-9.6 amd64 9.6.1-2 [494 kB]
Get:100 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-constantly all 15.1.0-1 [7,902 B]
Get:101 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-webencodings all 0.5-2 [10.3 kB]
Get:102 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-html5lib all 0.999999999-1 [88.0 kB]
Get:103 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-incremental all 16.10.1-3 [14.4 kB]
Get:104 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-secretstorage all 2.3.1-2 [13.8 kB]
Get:105 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-keyring all 10.1-1 [40.7 kB]
Get:106 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-keyrings.alt all 1.3-1 [16.4 kB]
Get:107 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-pycurl amd64 7.43.0-2 [61.6 kB]
Get:108 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-twisted-core all 16.6.0-2 [1,979 kB]
Get:109 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-twisted-web all 16.6.0-2 [79.8 kB]
Get:110 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-wheel all 0.29.0-2 [51.7 kB]
Get:111 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-yara amd64 3.5.0+dfsg-4 [13.8 kB]
Get:112 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 xsltproc amd64 1.1.29-2 [120 kB]
Get:113 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 sparta all 1.0.1+git20150729-0kali2 [257 kB]
Get:114 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 speech-dispatcher amd64 0.8.6-1 [364 kB]
Get:115 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 speech-dispatcher-audio-plugins amd64 0.8.6-1 [30.8 kB]
Get:116 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 speech-dispatcher-espeak-ng amd64 0.8.6-1 [45.3 kB]
Get:117 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 texlive-latex-base all 2016.20161130-1 [861 kB]
Get:118 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 texlive-base all 2016.20161130-1 [15.8 MB]
Get:119 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 tigervnc-common amd64 1.7.0+dfsg-2 [65.9 kB]
Get:120 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 tigervnc-standalone-server amd64 1.7.0+dfsg-2 [995 kB]
Get:121 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 tigervnc-viewer amd64 1.7.0+dfsg-2 [167 kB]
Get:122 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 tightvncserver amd64 1.3.9+t-1 [13.3 kB]
Get:123 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 xpdf amd64 3.04-4 [159 kB]
Get:124 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 xtightvncviewer amd64 1.3.9+t-1 [13.2 kB]
Get:125 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 zeitgeist-core amd64 0.9.16-0.2 [137 kB]
Get:126 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 aapt amd64 1:7.0.0+r1-2 [391 kB]
Get:127 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 gstreamer1.0-plugins-bad amd64 1.10.2-1 [2,971 kB]
Get:128 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libgstreamer-plugins-bad1.0-0 amd64 1.10.2-1 [1,874 kB]
Get:129 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 liblouis12 amd64 3.0.0-3 [86.8 kB]
Get:130 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libosinfo-1.0-0 amd64 1.0.0-2 [150 kB]
Get:131 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libradare2-1.1 amd64 1.1.0+dfsg-1 [2,052 kB]
Get:132 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 libradare2-dev amd64 1.1.0+dfsg-1 [146 kB]
Get:133 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python-twisted all 16.6.0-2 [12.2 kB]
Get:134 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 python3-louis all 3.0.0-3 [23.5 kB]
Get:135 http://kali.mirror.garr.it/mirrors/kali kali-rolling/main amd64 radare2 amd64 1.1.0+dfsg-1 [151 kB]
Fetched 166 MB in 6min 28s (427 kB/s)
Extracting templates from packages: 100%
Preconfiguring packages ...
main()
raise IOError(msg)
debconf
python
main()
raise IOError(msg)
python --version
Python 2.7.13
sudo apt autoremove
main()
raise IOError(msg)
debconf
