I was actually trying to update my python package to current version using update-alternatives. Since am not much familiar with it, I tried to get it done by watching YouTube videos. from one of such videos I unfortunately gave the command sudo unlink /usr/bin/python which soon after made terminal and software updater not working.but somehow I was able to open the terminal via "files" and also when I tried to install some new software(Xterm) via terminal at end of the process it shows like
kayalvizhi@eyegirl:~$ sudo apt-get install xterm
Reading package lists... Done
Building dependency tree
xterm is already the newest version (330-1ubuntu2).
The following packages were automatically installed and are no longer required:
libllvm7 libllvm9
Use 'sudo apt autoremove' to remove them.
The following packages will be upgraded:
python3-distupgrade
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
5 not fully installed or removed.
Need to get 0 B/106 kB of archives.
After this operation, 1,024 B of additional disk space will be used.
(Reading database ... 207547 files and directories currently installed.)
Preparing to unpack .../python3-distupgrade_1%3a18.04.38_all.deb ...
/var/lib/dpkg/info/python3-distupgrade.prerm: 6: /var/lib/dpkg/info/python3-distupgrade.prerm: py3clean: not found
dpkg: warning: old python3-distupgrade package pre-removal script subprocess returned error exit status 127
dpkg: trying script from the new package instead ...
/var/lib/dpkg/tmp.ci/prerm: 6: /var/lib/dpkg/tmp.ci/prerm: py3clean: not found
dpkg: error processing archive /var/cache/apt/archives/python3-distupgrade_1%3a 18.04.38_all.deb (--unpack):
new python3-distupgrade package pre-removal script subprocess returned error exit status 127
/var/lib/dpkg/info/python3-distupgrade.postinst: 6: /var/lib/dpkg/info/python3-distupgrade.postinst: py3compile: not found
dpkg: error while cleaning up:
installed python3-distupgrade package post-installation script subprocess returned error exit status 127
/var/cache/apt/archives/python3-distupgrade_1%3a18.04.38_all.deb
then I gave the command
sudo dpkg --configure -a
kayalvizhi@eyegirl:~$ sudo dpkg --configure -a
dpkg: dependency problems prevent configuration of ubuntu-release-upgrader-gtk:
ubuntu-release-upgrader-gtk depends on python3-distupgrade (= 1:18.04.38); however:
Version of python3-distupgrade on system is 1:18.04.37.
dpkg: error processing package ubuntu-release-upgrader-gtk (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of ubuntu-release-upgrader-core:
ubuntu-release-upgrader-core depends on python3-distupgrade (= 1:18.04.38); however:
dpkg: error processing package ubuntu-release-upgrader-core (--configure):
Setting up python3-lib2to3 (3.6.9-1~18.04) ...
Setting up python3-distutils (3.6.9-1~18.04) ...
dpkg: error processing package python3-distupgrade (--configure):
package is in a very bad inconsistent state; you should
reinstall it before attempting configuration
Setting up dh-python (3.20180325ubuntu2) ...
/var/lib/dpkg/info/dh-python.postinst: 6: /var/lib/dpkg/info/dh-python.postinst: py3compile: not found
dpkg: error processing package dh-python (--configure):
installed dh-python package post-installation script subprocess returned error exit status 127
dpkg: dependency problems prevent configuration of python3-all:
python3-all depends on dh-python; however:
Package dh-python is not configured yet.
dpkg: error processing package python3-all (--configure):
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
python3-distupgrade
dh-python
python3-all
and I also have a red sphere with a minus sign into it, whenever I take my cursor to it, it shows me like
a problem occurred when checking for the updates
How can I get back everything to be normal?
