-1
I'm a relatively inexperienced Linux user having a problem with Ubuntu LTS 14.04.1 LTS (installed from the MythBuntu DVD).
If I run 'sudo apt-get install', I see the following errors:
You might want to run 'apt-get -f install' to correct these.
 lib32gcc1 : Depends: gcc-4.9-base (= 4.9-20140406-0ubuntu1) but 4.9.1-0ubuntu1 is installed
 libc6-dbg : Depends: libc6 (= 2.19-0ubuntu6.3) but 2.19-0ubuntu6 is installed
 libc6-dev : Depends: libc6 (= 2.19-0ubuntu6.3) but 2.19-0ubuntu6 is installed
 libc6-i386 : Depends: libc6 (= 2.19-0ubuntu6.3) but 2.19-0ubuntu6 is installed
E: Unmet dependencies. Try using -f.
If I run 'sudo apt-get -f install', it starts off promising, but then chokes with the following:
Preconfiguring packages ...
dpkg: error processing package mount (--configure):
 package is in a very bad inconsistent state; you should
 reinstall it before attempting configuration
 mount
I'm not totally sure how to fix that, but whenever I run any dpkg or apt-get command that I think might help resolve the problem with mount, then it gives me errors about the unmet dependencies from above. Seems that even if I had the right approach to cleaning up mount, I couldn't execute it cause of the other errors which the problem with mount is preventing me from fixing.
How can I get package management working again?
Thanks in advance for your help.
Probably worth posting the contents of /etc/apt/sources.list for a more accurate diagnostic.
However, have you done a,
sudo apt-get update
Recently ?
ksb
