Please note: I'm a newbie with Ubuntu, only just beginning to get a grasp on terminal, etc.
Whenever I try to install anything using terminal, with
sudo apt-get install vlc
it works fine until I have confirmed additional disk space will be used.
After it has fetched all the necessary files and unpacked them, I get a long list starting with
dpkg: error processing [...]
And it ends with
Processing was halted because there weE: Sub-process /usr/bin/dpkg returned an
errorcode (1)
I already googled for a solution quite a bit but can't find anyone with the exact same issue.
Also, I don't know if it has anything to do with it, but I tried to get some additional plugins for an application I installed through software center and it gave me an error message saying
"An unhandlable error occured: There seems to be a programming error in aptdaemon, the software that allows you to install/remove software and to perform other package management related tasks."
Here's the full error log: http://pastebin.com/9YJSrf4a
181 not fully installed or removed.
Need to get 0 B/358 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
dpkg: error processing libkrb5-3:amd64 (--configure):
Package is in a very bad inconsistent state - you should
reinstall it before attempting configuration.
dpkg: dependency problems prevent configuration of libgssapi-krb5-2:amd64:
libgssapi-krb5-2:amd64 depends on libkrb5-3 (= 1.10.1+dfsg-4+nmu1); however:
Package libkrb5-3:amd64 is not configured yet.
dpkg: error processing libgssapi-krb5-2:amd64 (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libcurl3-gnutls:amd64:
libcurl3-gnutls:amd64 depends on libgssapi-krb5-2 (>= 1.10+dfsg~); however:
Package libgssapi-krb5-2:amd64 is not configured yet.
dpkg: error processing libcurl3-gnutls:amd64 (--configure):
dpkg: dependency problems prevent configuration of libcups2:amd64:
libcups2:amd64 depends on libgssapi-krb5-2 (>= 1.10+dfsg~); however:
dpkg: error processing libcups2:amd64 (--configure):
dpkg: dependency problems prevent configuration of libgtk2.0-0:amd64:
libgtk2.0-0:amd64 depends on libcups2 (>= 1.6.2); however:
Package libcups2:amd64 is not configured yet.
dpkg: error processing libgtk2.0-0:amd64 (--configure):
dpkg: dependency problems prevent configuration of chromium-browser:
chromium-browser depends on libcups2 (>= 1.4.0); however:
chromium-browser depends on libgssapi-krb5-2 (>= 1.6.dfsg.2); however:
chromium-browser depends on libgtk2.0-0 (>= 2.24.0); however:
Package libgtk2.0-0:amd64 is not configured yet.
chromium-browser depends on libkrb5-3 (>= 1.6.dfsg.2); however:
dpkg: error processing chromium-browser (--configure):
dpkg: dependency problems prevent configuration of chromium-browser-l10n:
chromium-browser-l10n depends on chromium-browser (>= 31.0.1650.63-0ubuntu0.13.04.1~20131204.1); however:
Package chromium-browser is not configured yet.
chromium-browser-l10n depends on chromium-browser (= 1.4.0); however:
dpkg: error processing libcupsfilters1:amd64 (--configure):
dpkg: dependency problems prevent configuration of libcupsimage2:amd64:
libcupsimage2:amd64 depends on libcups2 (= 1.6.2-1ubuntu5); however:
libcupsimage2:amd64 depends on libcupsfilters1 (>= 1.0~b1); however:
Package libcupsfilters1:amd64 is not configured yet.
dpkg: error processing libcupsimage2:amd64 (--configure):
dpkg: dependency problems prevent configuration of libgs9:
libgs9 depends on libcups2 (>= 1.4.0); however:
libgs9 depends on libcupsimage2 (>=No apport report written because MaxReports is reached already
1.4.0); however:
Package libcupsimage2:amd64 is not configured yet.
dpkg: error processing libgs9 (--configure):
dpkg: dependency problems prevent configuration of ghostscript:
ghostscript depends on libgs9 (= 9.07~dfsg2-0ubuntu3.1); however:
Package libgs9 is not configured yet.
dpkg: error processing ghostscript (--configure):
dpkg: dependency problems prevent configuration of cups-filters:
cups-filters depends on libcups2 (>= 1.4.0); however:
cups-filters depends on libcupsfilters1 (>= 1.0~b1); however:
cups-filters depends on libcupsimage2 (>= 1.4.0); however:
cups-filters depends on ghostscript (>= 9.02~); however:
Package ghostscript is not configured yet.
dpkg: error processing cups-filters (--configure):
dpkg: dependency problems prevent configuration of libsane-hpaio:
libsane-hpaio depends on libcups2 (>= 1.4.0); however:
dpkg: error processing libsane-hpaio (--configure):
dpkg: dependency problems prevent configuration of ghostscript-cups:
ghostscript-cups depends on libcups2 (>= 1.4.0); however:
ghostscript-cups depends on libcupsimage2 (>= 1.4.0); however:
ghostscript-cups depends on ghostscript (>= 8.64~dfsg-8); however:
dpkg: error processing ghostscript-cups (--configure):
dpkg: dependency problems prevent configuration of libcupscgi1:amd64:
libcupscgi1:amd64 depends on libcups2 (= 1.6.2-1ubuntu5); however:
dpkg: error processing libcupscgi1:amd64 (--configure):
dpkg: dependency problems prevent configuration of libcupsmime1:amd64:
libcupsmime1:amd64 depends on libcups2 (= 1.6.2-1ubuntu5); however:
dpkg: error processing libcupsmime1:amd64 (--configure):
dpkg: dependency problems prevent configuration of libcupsppdc1:amd64:
libcupsppdc1:amd64 depends on libcups2 (= 1.6.2-1ubuntu5); however:
dpkg: error processing libcupsppdc1:amd64 (--configure):
dpkg: dependency problems prevent configuration of cups-daemon:
cups-daemon depends on libcups2 (= 1.6.2-1ubuntu5); however:
cups-daemon depends on libcupsmime1 (>= 1.5.0); however:
Package libcupsmime1:amd64 is not configured yet.
cups-daemon depends on libgssapi-krb5-2 (>= 1.10+dfsg~); however:
dpkg: error processing cups-daemon (--configure):
dpkg: dependency problems prevent configuration of cups-client:
cups-client depends on libcups2 (= 1.6.2-1ubuntu5); however:
cups-client depends on libcupsimage2 (>= 1.4.0); however:
dpkg: error processing cups-client (--configure):
dpkg: dependency problems prevent configuration of cups-ppdc:
cups-ppdc depends on libcups2 (>= 1.6.2); however:
cups-ppdc depends on libcupsppdc1 (>= 1.4.0); however:
Package libcupsppdc1:amd64 is not configured yet.
dpkg: error processing cups-ppdc (--configure):
dpkg: dependency problems prevent configuration of cups:
cups depends on libcups2 (= 1.6.2-1ubuntu5); however:
cups depends on libcupscgi1 (>= 1.4.2); however:
Package libcupscgi1:amd64 is not configured yet.
cups depends on libcupsmime1 (>= 1.4.0); however:
cups depends on libcupsppdc1 (>= 1.4.0); however:
cups depends on cups-daemon (>= 1.6.2-1ubuntu5); however:
Package cups-daemon is not configured yet.
cups depends on ghostscript (>= 9.02~); however:
cups depends on cups-client (>= 1.6.2-1ubuntu5); however:
Package cups-client is not configured yet.
cups depends on cups-ppdc; however:
Package cups-ppdc is not configured yet.
cups depends on cups-filters (>= 1.0.24-3~); however:
Package cups-filt
dpkg: error processing cups (--configure):
dpkg: dependency problems prevent configuration of printer-driver-hpcups:
printer-driver-hpcups depends on libcups2 (>= 1.4.0); however:
printer-driver-hpcups depends on libcupsimage2 (>= 1.4.0); however:
printer-driver-hpcups depends on ghostscript-cups; however:
Package ghostscript-cups is not configured yet.
printer-driver-hpcups depends on cups (>= 1.4.0) | cupsddk; however:
Package cups is not configured yet.
Package cupsddk is not installed.
printer-driver-hpcups depends on cups; however:
dpkg: error processing printer-driver-hpcups (--configure):
dpkg: dependency problems prevent configuration of hplip:
hplip depends on libcups2 (>= 1.4.0); however:
hplip depends on libsane-hpaio (= 3.13.3-1ubuntu0.1); however:
Package libsane-hpaio is not configured yet.
hplip depends on printer-driver-hpcups (= 3.13.3-1ubuntu0.1); however:
Package printer-driver-hpcups is not configured yet.
hplip depends on cups (>= 1.1.20); however:
dpkg: error processing hplip (--configure):
dpkg: dependency problems prevent configuration of printer-driver-postscript-hp:
printer-driver-postscript-hp depends on hplip (>= 3.13.3-1ubuntu0.1); however:
Package hplip is not configured yet.
dpkg: error processing printer-driver-postscript-hp (--configure):
dpkg: dependency problems prevent configuration of printer-driver-foo2zjs:
printer-driver-foo2zjs depends on libcups2 (>= 1.4.0); however:
dpkg: error processing printer-driver-foo2zjs (--configure):
dpkg: dependency problems prevent configuration of printer-driver-c2esp:
printer-driver-c2esp depends on libcups2 (>= 1.4.0); however:
printer-driver-c2esp depends on libcupsfilters1 (>= 1.0~b1); however:
printer-driver-c2esp depends on libcupsimage2 (>= 1.4.0); however:
dpkg: error processing printer-driver-c2esp (--configure):
dpkg: dependency problems prevent configuration of libindicator7:
libindicator7 depends on libgtk2.0-0 (>= 2.18); however:
dpkg: error processing libindicator7 (--configure):
dpkg: dependency problems prevent configuration of libappindicator1:
libappindicator1 depends on libgtk2.0-0 (>= 2.20.0); however:
libappindicator1 depends on libindicator7 (>= 0.4.90); however:
Package libindicator7 is not configured yet.
dpkg: error processing libappindicator1 (--configure):
dpkg: dependency problems prevent configuration of libcanberra-gtk0:amd64:
libcanberra-gtk0:amd64 depends on libgtk2.0-0 (>= 2.24.0); however:No apport report written because MaxReports is reached already
dpkg: error processing libcanberra-gtk0:amd64 (--configure):
dpkg: dependency problems prevent configuration of gnome-session-canberra:
gnome-session-canberra depends on libcanberra-gtk0; however:
Package libcanberra-gtk0:amd64 is not configured yet.
dpkg: error processing gnome-session-canberra (--configure):
dpkg: dependency problems prevent configuration of libcurl3:amd64:
libcurl3:amd64 depends on libgssapi-krb5-2 (>= 1.10+dfsg~); however:No apport report written because MaxReports is reached already
dpkg: error processing libcurl3:amd64 (--configure):
dpkg: dependency problems prevent configuration of libcurl3-nss:amd64:
libcurl3-nss:amd64 depends on libgssapi-krb5-2 (>= 1.10+dfsg~); however:
dpkg: error processing libcurl3-nss:amd64 (--configure):
dpkg: dependency problems prevent configuration of libfreerdp-plugins-standard:amd64:
libfreerdp-plugins-standard:amd64 depends on libcups2 (>= 1.4.0); however:
dpkg: error processing libfreerdp-plugins-standard:amd64 (--configure):
dpkg: dependency problems prevent configuration of libgail18:amd64:
libgail18:amd64 depends on libgtk2.0-0 (= 2.24.17-0ubuntu2); however:
dpkg: error processing libgail18:amd64 (--configure):
dpkg: dependency problems prevent configuration of libmlt5:
libmlt5 depends on libgtk2.0-0 (>= 2.24.0); however:
dpkg: error processing libmlt5 (--configure):
dpkg: dependency problems prevent configuration of libmlt++3:
libmlt++3 depends on libmlt5; however:
Package libmlt5 is not configured yet.
dpkg: error processing libmlt++3 (--configure):
dpkg: dependency problems prevent configuration of liboauth0:amd64:
liboauth0:amd64 depends on libcurl3-gnutls (>= 7.16.2); however:
Package libcurl3-gnutls:amd64 is not configured yet.
dpkg: error processing liboauth0:amd64 (--configure):
dpkg: dependency problems prevent configuration of libufe-xidgetter0:
libufe-xidgetter0 depends on libgtk2.0-0 (>= 2.24.0); however:
dpkg: error processing libufe-xidgetter0 (--configure):
dpkg: dependency problems prevent configuration of libwxgtk2.8-0:amd64:
libwxgtk2.8-0:amd64 depends on libgtk2.0-0 (>= 2.24.0); however:
dpkg: error processing libwxgtk2.8-0:amd64 (--configure):
dpkg: dependency problems prevent configuration of melt:
melt depends on libmlt5; however:
dpkg: error processing melt (--configure):
dpkg: dependency problems prevent configuration of python-mlt5:
python-mlt5 depends on libmlt++3; however:
Package libmlt++3 is not configured yet.
python-mlt5 depends on libmlt5; however:
dpkg: error processing python-mlt5 (--configure):
dpkg: dependency problems prevent configuration of samba-common-bin:
samba-common-bin depends on libgssapi-krb5-2 (>= 1.10+dfsg~); however:
samba-common-bin depends on libkrb5-3 (>= 1.10+dfsg~); however:
dpkg: error processing samba-common-bin (--configure):
dpkg: dependency problems prevent configuration of smbclient:
smbclient depends on libgssapi-krb5-2 (>= 1.10+dfsg~); however:
smbclient depends on libkrb5-3 (>= 1.10+dfsg~); however:
dpkg: error processing smbclient (--configure):
dpkg: dependency problems prevent configuration of libsmbclient:amd64:
libsmbclient:amd64 depends on libgssapi-krb5-2 (>= 1.10+dfsg~); however:
libsmbclient:amd64 depends on libkrb5-3 (>= 1.10+dfsg~); however:
dpkg: error processing libsmbclient:amd64 (--configure):
dpkg: dependency problems prevent configuration of vlc-nox:
vlc-nox depends on libsmbclient (>= 3.0.24); however:
Package libsmbclient:amd64 is not configured yet.
dpkg: error processing vlc-nox (--configure):
dpkg: dependency problems prevent configuration of vlc-plugin-notify:
vlc-plugin-notify depends on vlc-nox (= 2.0.8-0ubuntu0.13.04.1); however:
Package vlc-nox is not configured yet.
vlc-plugin-notify depends on libgtk2.0-0 (>= 2.8.0); however:
dpkg: error processing vlc-plugin-notify (--configure):
dpkg: dependency problems prevent configuration of vlc:
vlc depends on vlc-nox (= 2.0.8-0ubuntu0.13.04.1); however:
dpkg: error processing vlc (--configure):
dpkg: dependency problems prevent configuration of vlc-plugin-pulse:
vlc-plugin-pulse depends on vlc-nox (= 2.0.8-0ubuntu0.13.04.1); however:
Package vlc-nox is not configured yet.No apport report written because MaxReports is reached already
dpkg: error processing vlc-plugin-pulse (--configure):
dpkg: dependency problems prevent configuration of whoopsie:
whoopsie depends on libcurl3 (>= 7.16.2); however:
Package libcurl3:amd64 is not configured yet.
dpkg: error processing whoopsie (--configure):
dpkg: dependency problems prevent configuration of apt-transport-https:
apt-transport-https depends on libcurl3-gnutls (>= 7.29.0-1ubuntu3.2); however:
dpkg: error processing apt-transport-https (--configure):
dpkg: dependency problems prevent configuration of openssh-client:
openssh-client depends on libgssapi-krb5-2 (>= 1.10+dfsg~); however:
dpkg: error processing openssh-client (--configure):
dpkg: too many errors, stopping
libkrb5-3:amd64
libcups2:amd64
libgtk2.0-0:amd64
chromium-browser
libcupsimage2:amd64
libgs9
ghostscript
cups-filters
libsane-hpaio
ghostscript-cups
libcupscgi1:amd64
libcupsmime1:amd64
libcupsppdc1:amd64
cups-daemon
cups-client
cups-ppdc
cups
hplip
libindicator7
libappindicator1
libcurl3:amd64
libcurl3-nss:amd64
libgail18:amd64
libmlt5
libmlt++3
liboauth0:amd64
libufe-xidgetter0
libwxgtk2.8-0:amd64
melt
python-mlt5
samba-common-bin
smbclient
libsmbclient:amd64
vlc-nox
vlc-plugin-notify
vlc
vlc-plugin-pulse
whoopsie
apt-transport-https
openssh-client
E: Sub-process /usr/bin/dpkg returned an error code (1)s.
