After upgrading to Ubuntu 18.04 LTS I was getting the following error
bash: /usr/bin/python3: No such file or directory
virtualenvwrapper.sh: There was a problem running the initialization hooks.
If Python could not import the module virtualenvwrapper.hook_loader,
check that virtualenvwrapper has been installed for
VIRTUALENVWRAPPER_PYTHON=/usr/bin/python3 and that PATH is set properly.
So after searching this problem online I ran the command sudo apt remove python3 which removed most of the thing from my OS like Chrome, GUI etc. I was able to recover my GUI but when I run the command sudo apt upgrade I get the following errors
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
106 not fully installed or removed.
Need to get 0 B/47.2 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
dpkg: error processing package python3 (--configure):
package is in a very bad inconsistent state; you should
reinstall it before attempting configuration
No apport report written because the error message indicates it's a follow-up error from a previous failure.
dpkg: dependency problems prevent configuration of update-notifier-common:
update-notifier-common depends on python3:any; however:
Package python3 is not configured yet.
dpkg: error processing package update-notifier-common (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of python3-lxml:amd64:
python3-lxml:amd64 depends on python3 (<< 3.7); however:
python3-lxml:amd64 depends on python3 (>= 3.6~); however:
python3-lxml:amd64 depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-lxml:amd64 (--configure):
dpkg: dependency problems prevent configuration of printer-driver-m2300w:
printer-driver-m2300w depends on python3; however:
dpkg: error pNo apport report written because the error message indicates it's a follow-up error from a previous failure.
No apport report written because MaxReports has already been reached
Processing package printer-driver-m2300w (--configure):
dpkg: dependency problems prevent configuration of usb-creator-gtk:
usb-creator-gtk depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package usb-creator-gtk (--configure):
dpkg: dependency problems prevent configuration of python3-olefile:
python3-olefile depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-olefile (--configure):
dpkg: dependency problems prevent configuration of ubuntu-web-launchers:
ubuntu-web-launchers depends on python3; however:
dpkg: error processing package ubuntu-web-launchers (--configure):
dpkg: dependNo apport report written because MaxReports has already been reached
dpkg: dependency problems prevent configuration of libglib2.0-dev-bin:
libglib2.0-dev-bin depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package libglib2.0-dev-bin (--configure):
dpkg: dependency problems prevent configuration of rhythmbox-plugin-zeitgeist:
rhythmbox-plugin-zeitgeist depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package rhythmbox-plugin-zeitgeist (--configure):
dpkg: dependency problems prevent configuration of python3-brlapi:
python3-brlapi depends on python3 (<< 3.7); however:
python3-brlapi depends on python3 (>= 3.6~); however:
python3-brlapi depends on python3:any (>= 3.2~); however:
dpkg: error proNo apport report written because MaxReports has already been reached
Processing package python3-brlapi (--configure):
dpkg: dependency problems prevent configuration of python3-commandnotfound:
python3-commandnotfound depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-commandnotfound (--configure):
dpkg: dependency problems prevent configuration of printer-driver-postscript-hp:
printer-driver-postscript-hp depends on python3; however:
dpkg: error processing package printer-driver-postscript-hp (--configure):
dpkg: dependency problems prevent configuration of python3-numpy:
python3-numpy depends on python3 (<< 3.7); however:
python3-numpy depends on python3 (>= 3.6~); however:
python3-numpy depends on python3:any (>= 3.4~); however:
dpkg: error processing package python3-numpy (--configure):
dpkg: dependency problems prevent configuration of system-config-printer-common:
system-config-printer-common depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package system-config-printer-common (--configure):
dpkg: dependency problems prevent configuration of language-selector-common:
language-selector-common depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package language-selector-common (--configure):
dpkg: dependency problems prevent configuration of printer-driver-foo2zjs-common:
printer-driver-foo2zjs-common depends on python3; however:
dpkg: error processing package printer-driver-foo2zjs-common (--configure):
dpkg: dependency problems prevent configuration of python3-keyrings.alt:
python3-keyrings.alt depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-keyrings.alt (--configure):
dpkg: dependency problems prevent configuration of apt-xapian-index:
apt-xapian-index depends on python3:any (>= 3.4~); however:
dpkg: error processing package apt-xapian-index (--configure):
dpkg: dependency problems prevent configuration of openprinting-ppds:
openprinting-ppds depends on python3; however:
dpkg: error processing package openprinting-ppds (--configure):
dpkg: dependency problems prevent configuration of apparmor:
apparmor depends on python3:any; however:
dpkg: error processing package apparmor (--configure):
dpkg: dependency problems prevent configuration of gnome-shell:
gnome-shell depends on python3; however:
dpkg: error processing package gnome-shell (--configure):
dpkg: dependency problems prevent configuration of apport-gtk:
apport-gtk depends on python3; however:
dpkg: error processing package apport-gtk (--configure):
dpkg: dependency problems prevent configuration of python3-aptdaemon.gtk3widgets:
python3-aptdaemon.gtk3widgets depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-aptdaemon.gtk3widgets (--configure):
dpkg: dependency problems prevent configuration of apturl:
apturl depends on python3:any (>= 3.3.2-2~); however:
apturl depends on python3-aptdaemon.gtk3widgets; however:
Package python3-aptdaemon.gtk3widgets is not configured yet.
dpkg: error processing package apturl (--configure):
dpkg: dependency problems prevent configuration of python3-wheel:
python3-wheel depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-wheel (--configure):
dpkg: dependency problems prevent configuration of python3-gi-cairo:
python3-gi-cairo depends on python3 (<< 3.7); however:
python3-gi-cairo depends on python3 (>= 3.6~); however:
python3-gi-cairo depends on python3:any (>= 3.3~); however:
dpkg: error processing package python3-gi-cairo (--configure):
dpkg: dependency problems prevent configuration of hplip-data:
hplip-data depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package hplip-data (--configure):
dpkg: dependency problems prevent configuration of python3-bs4:
python3-bs4 depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-bs4 (--configure):
dpkg: dependency problems prevent configuration of lsb-release:
lsb-release depends on python3:any (>= 3.4~); however:
dpkg: error processing package lsb-release (--configure):
dpkg: dependency problems prevent configuration of gnome-control-center:
gnome-control-center depends on system-config-printer-common (>= 1.4); however:
Package system-config-printer-common is not configured yet.
dpkg: error processing package gnome-control-center (--configure):
dpkg: dependency problems prevent configuration of orca:
orca depends on python3:any (>= 3.3.2-2~); however:
orca depends on python3-brlapi (>= 0.5.1); however:
Package python3-brlapi is not configured yet.
dpkg: error processing package orca (--configure):
dpkg: dependency problems prevent configuration of gnome-terminal:
gnome-terminal depends on python3; however:
dpkg: error processing package gnome-terminal (--configure):
dpkg: dependency problems prevent configuration of ubuntu-session:
ubuntu-session depends on gnome-shell (>= 3.24.3-0ubuntu2); however:
Package gnome-shell is not configured yet.
dpkg: error processing package ubuntu-session (--configure):
dpkg: dependency problems prevent configuration of python3-asn1crypto:
python3-asn1crypto depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-asn1crypto (--configure):
dpkg: dependency problems prevent configuration of python3-blinker:
python3-blinker depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-blinker (--configure):
dpkg: dependency problems prevent configuration of python3-reportlab:
python3-reportlab depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-reportlab (--configure):
dpkg: dependency problems prevent configuration of gnome-tweaks:
gnome-tweaks depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package gnome-tweaks (--configure):
dpkg: dependency problems prevent configuration of python3-feedparser:
python3-feedparser depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-feedparser (--configure):
dpkg: dependency problems prevent configuration of python3-macaroonbakery:
python3-macaroonbakery depends on python3:any (>= 3.5~); however:
dpkg: error processing package python3-macaroonbakery (--configure):
dpkg: dependency problems prevent configuration of snapd:
snapd depends on apparmor (>= 2.10.95-0ubuntu2.2); however:
Package apparmor is not configured yet.
dpkg: error processing package snapd (--configure):
dpkg: dependency problems prevent configuration of printer-driver-pxljr:
printer-driver-pxljr depends on python3; however:
dpkg: error processing package printer-driver-pxljr (--configure):
dpkg: dependency problems prevent configuration of python3-debconf:
python3-debconf depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-debconf (--configure):
dpkg: dependency problems prevent configuration of python3-uno:
python3-uno depends on python3:any (>= 3.3.2-2~); however:
python3-uno depends on python3 (<< 3.7); however:
python3-uno depends on python3 (>= 3.6~); however:
dpkg: error processing package python3-uno (--configure):
dpkg: dependency problems prevent configuration of software-properties-gtk:
software-properties-gtk depends on python3:any (>= 3.3.2-2~); however:
software-properties-gtk depends on python3; however:
software-properties-gtk depends on python3-aptdaemon.gtk3widgets; however:
dpkg: error processing package software-properties-gtk (--configure):
dpkg: dependency problems prevent configuration of python3-oauthlib:
python3-oauthlib depends on python3:any (>= 3.4~); however:
python3-oauthlib depends on python3-blinker; however:
Package python3-blinker is not configured yet.
dpkg: error processing package python3-oauthlib (--configure):
dpkg: dependency problems prevent configuration of ubuntu-system-service:
ubuntu-system-service depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package ubuntu-system-service (--configure):
dpkg: dependency problems prevent configuration of python3-pexpect:
python3-pexpect depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-pexpect (--configure):
dpkg: dependency problems prevent configuration of python3-systemd:
python3-systemd depends on python3 (<< 3.7); however:
python3-systemd depends on python3 (>= 3.6~); however:
python3-systemd depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-systemd (--configure):
dpkg: dependency problems prevent configuration of xdiagnose:
xdiagnose depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package xdiagnose (--configure):
dpkg: dependency problems prevent configuration of update-notifier:
update-notifier depends on update-notifier-common (= 3.192.1.7); however:
Package update-notifier-common is not configured yet.
dpkg: error processing package update-notifier (--configure):
dpkg: dependency problems prevent configuration of python3-all:
python3-all depends on python3 (= 3.6.7-1~18.04); however:
dpkg: error processing package python3-all (--configure):
dpkg: too many errors, stopping
python3
python3-lxml:amd64
usb-creator-gtk
python3-olefile
libglib2.0-dev-bin
python3-brlapi
python3-numpy
apt-xapian-index
openprinting-ppds
apparmor
gnome-shell
apport-gtk
apturl
python3-wheel
python3-gi-cairo
hplip-data
python3-bs4
lsb-release
orca
gnome-terminal
ubuntu-session
python3-asn1crypto
python3-blinker
python3-reportlab
gnome-tweaks
python3-feedparser
snapd
python3-debconf
python3-uno
python3-oauthlib
python3-pexpect
python3-systemd
xdiagnose
update-notifier
python3-all
Processing was halted because there were too many errors.
Can somebody help me to overcome this situation?
