So this seems simple, but I've been googling for days.
An install of gitlab went wrong, so I tried to purge it to reinstall, however I get this:
dpkg: error processing package gitlab-ce (--remove):
    package is in a very bad inconsistent state; you should
    reinstall it before attempting a removal
However trying to install it causes it to hang at 6%, the problem it had initially. I'm no longer needing gitlab at all (I'm using gitea on a different machine), but this problem is preventing me from installing anything at any time I use apt to install something it also wants to install gitlab at the same time, which again hangs at 6%.
For example sudo apt-get install curl shows this:
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
    gitlab-ce libcurl4
The following packages will be upgraded:
    curl gitlab-ce libcurl4
3 upgraded, 0 newly installed, 0 to remove and 65 not upgraded.
1 not fully installed or removed.
Need to get 472 MB of archives.
After this operation, 1460 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 curl amd64 7.58.0-2ubuntu3.5 [159 kB]
Get:2 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 libcurl4 amd64 7.58.0-2ubuntu3.5 [214 kB]
Get:3 https://packages.gitlab.com/gitlab/gitlab-ce/ubuntu bionic/main amd64 gitlab-ce amd64 11.5.0-ce.0 [472 MB]
Fetched 287 MB in 18s (16.3 MB/s)
(Reading database ... 54181 files and directories currently installed.)
Preparing to unpack .../gitlab-ce_11.5.0-ce.0_amd64.deb ...
Melebius
  • 11,750
Too many similar questions exist in AskUbuntu
  1. Package is in a very bad inconsistent state
  2. How to fix "Package is in a very bad inconsistent state" error?
  3. dpkg: "Package is in a very bad inconsistent state" how to fix it?
but its one has its own singularity.
The general answer is
package is in a very bad inconsistent state - you should reinstall it before attempting configuration.
The issue is easy to fix. Just reinstall the package:
sudo apt-get --reinstall install gitlab-ce
But in case you don't want to install it, or you cannot because it stuck, you can always use the --force-all option in dpkg.
Be Careful with this option as it can break things badly.
sudo dpkg -P --force-all gitlab-ce
Also, if you have any PPA enabled that provides gitlab-ce, please disable it or completely remove it.
NickTux
  • 17,865
  • 57
  • 66
