I guess my package manager is not working because dash is not available.
ubuntu@ubuntu:~$ sudo apt install hello
Reading package lists... Done
Building dependency tree... Done
The following NEW packages will be installed:
  hello
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
184 not fully installed or removed.
Need to get 0 B/119 kB of archives.
After this operation, 111 kB of additional disk space will be used.
dpkg: error processing package dash (--configure):
 package is in a very bad inconsistent state; you should
 reinstall it before attempting configuration
 dash
ubuntu@ubuntu:~$ hello
Command 'hello' not found, but can be installed with:
sudo snap install hello              # version 2.10, or
sudo apt  install hello              # version 2.10-2ubuntu4
sudo apt  install hello-traditional  # version 2.10-5
See 'snap info hello' for additional versions.
FeXa
I solved the problem. It's pretty easy. It worked when I typed the following line.
sudo apt reinstall dash
FeXa
