I was trying to install the printer driver for Brother HL-2280DW, but I had to stop it due to the printer not appearing to any of the PCs anymore. After I stopped it I noticed this error when I attempt to perform a apt-get upgrade.
Here's a snippet of what output I receive:
sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/2,834 B of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
dpkg: error processing package lsb-graphics (--configure):
 package is in a very bad inconsistent state; you should
 reinstall it before attempting configuration
 lsb-graphics
Is it safe to just remove lsb-graphics forcefully and reinstall it? I though I should ask first instead.
EDIT I went ahead and removed it using dpkg --remove --force-remove-reinstreq and then reinstalling it with apt-get install. Is there anything that I have to reconfigure, or is it fine as is?
Mo2
  • 386
dpkg --remove will keep config files, in contrast to dpkg --purge, so your config should still be there.
Jan
  • 12,931
  • 34
  • 39
