I first run sudo dpkg --remove jenkins and I get a response :
dpkg: error processing package jenkins (--remove):
package is in a very bad inconsistent state; you should
reinstall it before attempting a removal
    jenkins
So I then try with sudo apt-get --reinstall install jenkins and result is :
    Reading package lists... Done
    Building dependency tree
The following packages will be upgraded:
  jenkins
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/68.9 MB of archives.
After this operation, 895 kB of additional disk space will be used.
Selecting previously unselected package jenkins.
(Reading database ... 346826 files and directories currently installed.)
Preparing to unpack .../jenkins_2.19.1_all.deb ...
Not configured to run standalone
invoke-rc.d: initscript jenkins, action "stop" failed.
dpkg: warning: subprocess old pre-removal script returned error exit status 1
dpkg: trying script from the new package instead ...
dpkg: error processing archive /var/cache/apt/archives/jenkins_2.19.1_all.deb (--unpack):
 subprocess new pre-removal script returned error exit status 1
invoke-rc.d: initscript jenkins, action "start" failed.
dpkg: error while cleaning up:
 subprocess installed post-installation script returned error exit status 1
Anyone can tell what should I do to fix and update the package ?
mt0s
  • 163
You have to add --force-overwrite suffix on dpkg command, this will overwrite file that causing the error.
sudo dpkg -r --force-overwrite (file)
In your case, it would be
sudo dpkg -r --force-overwrite /var/cache/apt/archives/jenkins_2.19.1_all.deb
Make sure everything is fixed by running:
sudo apt-get -f install
Liso
  • 15,677
