I'm kind of new to Ubuntu. A couple of days ago, I upgraded to 16.04 from 14.04. After the upgrade, I can neither install new software nor upgrade OS. When I enter
 sudo apt-get upgrade
I get this is my output:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages will be upgraded:
  apt apt-transport-https apt-utils gcc-doc libapt-inst2.0 libapt-pkg5.0
6 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 2.011 kB/2.014 kB of archives.
After this operation, 6.144 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://mirror.ni.net.tr/ubuntu xenial-updates/main amd64 libapt-pkg5.0 amd64 1.2.12~ubuntu16.04.1 [696 kB]
Get:2 http://mirror.ni.net.tr/ubuntu xenial-updates/main amd64 libapt-inst2.0 amd64 1.2.12~ubuntu16.04.1 [55,4 kB]
Get:3 http://mirror.ni.net.tr/ubuntu xenial-updates/main amd64 apt amd64 1.2.12~ubuntu16.04.1 [1.038 kB]
Get:4 http://mirror.ni.net.tr/ubuntu xenial-updates/main amd64 apt-utils amd64 1.2.12~ubuntu16.04.1 [196 kB]
Get:5 http://mirror.ni.net.tr/ubuntu xenial-updates/main amd64 apt-transport-https amd64 1.2.12~ubuntu16.04.1 [25,7 kB]
Fetched 2.011 kB in 2s (859 kB/s)
(Reading database ... 325999 files and directories currently installed.)
Preparing to unpack .../gcc-doc_4%3a5.3.1-1ubuntu1_amd64.deb ...
install-info: No dir file specified; try --help for more information.
dpkg: warning: subprocess old pre-removal script returned error exit         status 1
dpkg: trying script from the new package instead ...
dpkg: error processing archive /var/cache/apt/archives/gcc-    doc_4%3a5.3.1-1ubuntu1_amd64.deb (--unpack):
 there is no script in the new version of the package - giving up
dpkg: error while cleaning up:
subprocess installed post-installation script returned error exit     status 1
Preparing to unpack .../libapt-pkg5.0_1.2.12~ubuntu16.04.1_amd64.deb     ...
Unpacking libapt-pkg5.0:amd64 (1.2.12~ubuntu16.04.1) over     (1.2.10ubuntu1)     ...
Processing triggers for libc-bin (2.23-0ubuntu3) ...
 /var/cache/apt/archives/gcc-doc_4%3a5.3.1-1ubuntu1_amd64.deb
Using the error code below I searched for solutions in the AskUbuntu but couldn't find one that works.
I have gcc-doc waiting to be upgraded in the Software Center. When I try to upgrade it on Software Center it takes forever and there is no upgrade. In Synaptics it halts the upgrade because of gcc-doc.
Thanks a lot for the help in advance.
itnet7
  • 3,509
I had the same problem here. Then after googling, I found solution (i hope) on How to fix "Package is in a very bad inconsistent state" error?
Run:
sudo mv /var/lib/dpkg/info/<packagename>.* /tmp/
sudo dpkg --remove --force-remove-reinstreq <packagename>
sudo apt-get remove <packagename>
sudo apt-get autoremove && sudo apt-get autoclean
