dpkg: error processing package apport (--configure):
package is in a very bad inconsistent state; you should
reinstall it before attempting configuration
apport
I have already tried removing apport but it still shows the same error after installation of any package....Please help
So I tried reinstalling...It showed again some errors...
sudo apt install apport --reinstall
[sudo] password for abhijeet:
Reading package lists... Done
Building dependency tree
Suggested packages:
apport-gtk | apport-kde
The following packages will be upgraded:
apport
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/120 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ... 239978 files and directories currently installed.)
Preparing to unpack .../apport_2.20.1-0ubuntu2.5_all.deb ...
File "/usr/bin/pyclean", line 63
except (IOError, OSError), e:
SyntaxError: invalid syntax
dpkg: warning: subprocess old pre-removal script returned error exit status 1
dpkg: trying script from the new package instead ...
dpkg: error processing archive /var/cache/apt/archives/apport_2.20.1-0ubuntu2.5_all.deb (--unpack):
subprocess new pre-removal script returned error exit status 1
Traceback (most recent call last):
File "/usr/bin/pycompile", line 35, in <module>
from debpython.version import SUPPORTED, debsorted, vrepr, \
File "/usr/share/python/debpython/version.py", line 24, in <module>
from ConfigParser import SafeConfigParser
ImportError: No module named 'ConfigParser'
dpkg: error while cleaning up:
subprocess installed post-installation script returned error exit status 1
