I try to install libness3-dev and I always get this error. Can somebody help me please?
 python-pip
 python3
 dh-python
Here ist the full error message:
> Reading package lists... Done Building dependency tree        Reading
> state information... Done nodejs is already the newest version
> (6.15.0-1nodesource1). 0 upgraded, 0 newly installed, 0 to remove and
> 0 not upgraded. 5 not fully installed or removed. Need to get 0 B/464
> kB of archives. After this operation, 0 B of additional disk space
> will be used. Do you want to continue? [Y/n] Y perl: warning: Setting
> locale failed. perl: warning: Please check that your locale settings:
>   LANGUAGE = (unset),     LC_ALL = (unset),   LC_CTYPE = "UTF-8",     LANG =
> "en_US.UTF-8"
>     are supported and installed on your system. perl: warning: Falling back to a fallback locale ("en_US.UTF-8"). locale: Cannot set LC_CTYPE
> to default locale: No such file or directory locale: Cannot set LC_ALL
> to default locale: No such file or directory Setting up python-pip
> (8.1.1-2ubuntu0.4) ... /var/lib/dpkg/info/python-pip.postinst: 6:
> /var/lib/dpkg/info/python-pip.postinst: pycompile: not found dpkg:
> error processing package python-pip (--configure):  subprocess
> installed post-installation script returned error exit status 127
> dpkg: error processing package python-pkg-resources (--configure):
> package is in a very bad inconsistent state; you should  reinstall it
> before attempting configuration dpkg: dependency problems prevent
> configuration of python-setuptools:  python-setuptools depends on
> python-pkg-resources (= 33.1.1-1+certbot~xenial+1); however:   Package
> python-pkg-resources is not configured yet.
> dpkg: error processing package python-setuptools (--configure):
> dependency problems - leaving unconfigured Setting up python3
> (3.5.1-3) ... running python rtupdate hooks for python3.5...
> /usr/share/python3/runtime.d/dh-python.rtupdate: 5:
> /usr/share/python3/runtime.d/dh-python.rtupdate: py3clean: not found
> error running python rtupdate hook dh-python dpkg: error processing
> package python3 (--configure):  subprocess installed post-installation
> script returned error exit status 4 dpkg: dependency problems prevent
> configuration of dh-python:  dh-python depends on python3:any (>=
> 3.3.2-2~); however:   Package python3 is not configured yet.
> dpkg: error processing package dh-python (--configure):  dependency
> problems - leaving unconfigured Errors were encountered while
> processing:  python-pip  python-pkg-resources  python-setuptools
> python3  dh-python E: Sub-process /usr/bin/dpkg returned an error code
> (1)
Distribution: 4.4.0-137-generic #163-Ubuntu SMP Mon Sep 24 13:14:43 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
abu_bua
  • 11,313
