I have been trying to remove MySQL from my node, but it fails removal. I have tried remove, purge, dpkg --force-all, to no effect. Suggestions?
dpkg --purge --force-all mysql-server-8.0
dpkg: warning: overriding problem because --force enabled:
dpkg: warning: package is in a very bad inconsistent state; you should
reinstall it before attempting a removal
(Reading database ... 281877 files and directories currently installed.)
Removing mysql-server-8.0 (8.0.22-0ubuntu0.20.04.3) ...
Failed to stop mysql.service: Unit mysql.service not loaded.
invoke-rc.d: initscript mysql, action "stop" failed.
dpkg: error processing package mysql-server-8.0 (--purge):
installed mysql-server-8.0 package pre-removal script subprocess returned error exit status 1
Failed to start mysql.service: Unit mysql.service not found.
invoke-rc.d: initscript mysql, action "start" failed.
Unit mysql.service could not be found.
dpkg: error while cleaning up:
installed mysql-server-8.0 package post-installation script subprocess returned error exit status 1
mysql-server-8.0
dpkg --install /var/cache/apt/archives/mysql-server-8.0_8.0.23-0ubuntu0.20.04.1_amd64.deb
Selecting previously unselected package mysql-server-8.0.
(Reading database ... 281878 files and directories currently installed.)
Preparing to unpack .../mysql-server-8.0_8.0.23-0ubuntu0.20.04.1_amd64.deb ...
dpkg: warning: old mysql-server-8.0 package pre-removal script subprocess returned error exit status 1
dpkg: trying script from the new package instead ...
dpkg: error processing archive /var/cache/apt/archives/mysql-server-8.0_8.0.23-0ubuntu0.20.04.1_amd64.deb (--install):
new mysql-server-8.0 package pre-removal script subprocess returned error exit status 1
apt install --reinstall mysql-server-8.0
Reading package lists... Done
Building dependency tree
Suggested packages:
mailx tinyca
The following packages will be upgraded:
mysql-server-8.0
1 upgraded, 0 newly installed, 0 to remove and 53 not upgraded.
1 not fully installed or removed.
Need to get 0 B/1,275 kB of archives.
After this operation, 14.3 kB of additional disk space will be used.
Preconfiguring packages ...
dpkg: error processing archive /var/cache/apt/archives/mysql-server-8.0_8.0.23-0ubuntu0.20.04.1_amd64.deb (--un
pack):
Failed command list:
All of the following failed, same error as above:
dpkg --install mysql-server-8.0
dpkg --remove --force-all mysql-server-8.0
dpkg --configure -a
