After installing a Bluetooth driver, the following error is shown, I have tried everything without any success. Following is the log that it shows when I try to fix it.
esar@cesar-P43E:~$ sudo apt install --fix-broken
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 58 not upgraded.
1 not fully installed or removed.
Need to get 0 B/55.4 kB of archives.
After this operation, 0 B of additional disk space will be used.
dpkg: error processing package libpam0g:amd64 (--configure):
 package is in a very bad inconsistent state; you should
 reinstall it before attempting configuration
 libpam0g:amd64
How can I solve this?
I have tried the following:
$ sudo apt-get install --reinstall liblmdb0
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 66 not upgraded.
Need to get 0 B/100 kB of archives.
 libpam0g:amd64
$ sudo apt --purge remove liblmdb0:amd64
E: The package libpam0g needs to be reinstalled, but I can't find an archive for it.
$ sudo apt-get autoremove
sudo apt-get update, sudo dpkg --configure -a returned no error.
$ sudo apt-get install -f
$ sudo apt remove libpam0g
[sudo] password for cesar:
I really do not know what to do in order to solve the problem.
Kulfy
  • 18,154
