After an apt-get upgrade I got the following error:
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
Setting up python3.3-minimal (3.3.1-1ubuntu5) ...
Traceback (most recent call last):
File "/usr/lib/python3.3/py_compile.py", line 8, in <module>
    import imp
  File "/usr/lib/python3.3/imp.py", line 28, in <module>
    import tokenize
  File "/usr/lib/python3.3/tokenize.py", line 28, in <module>
    import re
  File "/usr/lib/python3.3/re.py", line 122, in <module>
    import sre_compile
  File "/usr/lib/python3.3/sre_compile.py", line 14, in <module>
    import sre_parse
  File "/usr/lib/python3.3/sre_parse.py", line 17, in <module>
    from sre_constants import *
  File "/usr/lib/python3.3/sre_constants.py", line 18, in <module>
    from _sre import MAXREPEAT
ImportError: cannot import name MAXREPEAT
dpkg: error processing python3.3-minimal (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of python3.3:
 python3.3 depends on python3.3-minimal (= 3.3.1-1ubuntu5); however:
  Package python3.3-minimal is not configured yet.
dpkg: error processing python3.3 (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error     from a previous failure.
 python3.3-minimal
 python3.3
and I can't turn off my computer...
I guess I did not install correctly python 3.3, but how can I repair it?
Edit: I tried apt-get --reinstall install python2 python2-support but I got: the same error
EDIT: More information
on my system: Linux Mycomputer 3.5.0-34-generic #55-Ubuntu SMP Thu Jun 6 20:20:19 UTC 2013 i686 i686 i686 GNU/Linux
dpkg --print-architecture
i386
I used to have ubuntu 12.10. My problem occured when I tried upgrading it to 13.04. I had a error message telling me the process stoped because there were too many errors.
I then tried to run sudo apt-get update && sudo apt-get upgrade but encountered the error above.
I had a similar problem a few months ago when I mistakenly deleted python2 from my computer. I then could not turn off my computer by clicking on the icon (it does not respond) and turning off. The only way was to force it to shut down manually. When I turned it on again, I just had an empty desktop and could not do anything. This was fixed by reinstalling the whole system.
Searching on the internet, I tried several commands:
sudo dpkg --configure -a
which resulted in
    import imp
       import tokenize
    import re
    import sre_compile
    import sre_parse
dpkg: dependency problems prevent configuration of python3-minimal:
 python3-minimal depends on python3.3-minimal (>= 3.3.1-1~); however:
sudo apt-get --reinstall install python3 python3-support
E: Unable to locate package python3-support
sudo apt-get -f install
4 not fully installed or removed.
    import imp
    import tokenize
    import re
    import sre_compile
    import sre_parse
dpkg: error processing python3-minimal (--configure):
dpkg: dependency problems prevent configuration of python3:
 python3 depends on python3.3 (>= 3.3.1-1~); however:
  Package python3.3 is not configured yet.
 python3 depends on python3-minimal (= 3.3.1-0ubuntu1); however:
  Package python3-minimal is not configured yet.
dpkg: error processing python3 (--configure):
 python3.3-minimal
 python3-minimal
 python3.3
 python3
 python3.3-minimal
 python3-minimal
 python3
 python3.3
python --version
returns Python 2.7.4
Doing:
cd /tmp
sudo apt-get download python3
sudo dpkg -i python3*.deb && apt-get dist-upgrade
returns
    (Reading database ... 374310 files and directories currently installed.)
Preparing to replace python3 3.3.1-0ubuntu1 (using python3_3.3.1-0ubuntu1_i386.deb) ...
running python pre-rtupdate hooks for python3.3...
Unpacking replacement python3 ...
dpkg: error processing python3 (--install):
Processing triggers for man-db ...
 python3
I also tried to remove and reinstall python3
Any help please?
Edited after Gx1sptDTDa's answer
sudo apt-get clean
sudo apt-get dist-upgrade
Calculating upgrade... Done
    import imp
    import tokenize
    import re
    import sre_compile
    import sre_parse
 python3.3-minimal
 python3-minimal
 python3.3
 python3
Edit: Installation of all the dependencies for python3.3-minimal
sudo apt-get install libc6 libexpat1 libpython3.3-minimal zlib1g
returns
libc6 is already the newest version.
libexpat1 is already the newest version.
libpython3.3-minimal is already the newest version.
libpython3.3-minimal set to manually installed.
zlib1g is already the newest version.
    import imp
    import tokenize
    import re
    import sre_compile
    import sre_parse
 python3.3-minimal
 python3-minimal
 python3.3
 python3
EDIT: sudo dbkg-reconfigure -a
1/ Asks: ─────────────────────────────┤ Adduser ├────────────────────────────────┐
│ By default, users' home directories are readable by all users on the │
│ system. If you want to increase security and privacy, you might want │
│ home directories to be readable only for their owners. But if in doubt, │
│ leave this option enabled. │
│ This will only affect home directories of users added from now on with │
│ the adduser command. │
│ Do you want system-wide readable home directories?
Said yes
2/ ┤ Configuring apparmor ├──────────────────────────┐
│ Please enter a space separated list of any additional locations for user │
│ home directories. These locations are in addition to those specified in │
│ /etc/apparmor.d/tunables/home and must end with a '/'. │
│ Example: if user's directories are stored in /srv/nfs/home and │
│ /mnt/homes, you should enter "/srv/nfs/home/ /mnt/homes/". │
│ Additional home directory locations:
I don't know what location to indicate... so I just pass
Finally, I read on the shell:
update-rc.d: warning: /etc/init.d/acpi-support missing LSB information
update-rc.d: see <http://wiki.debian.org/LSBInitScripts>
acpid stop/waiting
acpid start/running, process 24816
 * Starting AppArmor
profiles                                                              Skipping
 profile in /etc/apparmor.d/disable: usr.bin.firefox
Skipping profile in /etc/apparmor.d/disable: usr.sbin.rsyslogd
        [ OK ]
 * Reloading AppArmor profiles
Skipping     profile in /etc/apparmor.d/disable: usr.bin.firefox
        [ OK ]
gpg: key 437D05B5: "Ubuntu Archive Automatic Signing Key <ftpmaster@ubuntu.com>"
not     changed
gpg: key FBB75451: "Ubuntu CD Image Automatic Signing Key <cdimage@ubuntu.com>"
not     changed
gpg: key C0B21F32: "Ubuntu Archive Automatic Signing Key (2012)
  <ftpmaster@ubuntu.com>"     not changed
gpg: key EFE21092: "Ubuntu CD Image Automatic Signing Key (2012)
<cdimage@ubuntu.com>"     not changed
gpg: Total number processed: 4
gpg:              unchanged: 4
Unknown media type in type 'all/all'
Unknown media type in type 'all/allfiles'
Unknown media type in type 'uri/mms'
Unknown media type in type 'uri/mmst'
Unknown media type in type 'uri/mmsu'
Unknown media type in type 'uri/pnm'
Unknown media type in type 'uri/rtspt'
Unknown media type in type 'uri/rtspu'
/usr/sbin/dpkg-reconfigure: asymptote is broken or not fully installed
Edit: Synaptic On synaptic, no "broken dependencies" is displayed (I click on status and all I can see is: All Installed Installed (local or obsolete) Installed (manual) Not installed Not installed (residual config)
Anwar
  • 77,855
bigTree
  • 457
EDIT
The problem was related to the following bug report: https://bugs.launchpad.net/ubuntu/+source/ubuntu-release-upgrader/+bug/1165281
Follow steps in comment #3 to #5, but change the path to python3.3 rather than 2.7.
Gx1sptDTDa
  • 1,663
  • 15
  • 24
I had the same problem with a different package, libamd2.3.1:amd64. I got this error:
> sudo apt upgrade
 libamd2.3.1:amd64
Following this thread, I managed to remove it with dpkg and reinstall with apt.
sudo dpkg --remove --force-remove-reinstreq libamd2.3.1:amd64
sudo apt-get install libamd2.3.1:amd64
