I am running Ubuntu 16.04 and have a problem with libxcursor1:amd64 which is causing everything to run really slow and not allow packages to be updated.
I have tried apt-get -f install to fix things and got this:
dpkg: error processing package libxcursor1:amd64 (--configure):
package is in a very bad inconsistent state; you should
reinstall it before attempting configuration
libxcursor1:amd64
I have tried to force it to remove the package and reinstall it (failed). I have tried going into recovery mode and running it before everything loads, and this failed. Really stuck, as the laptop is unusable.
Thanks, Dom.
N0rbert
  • 103,263
dombov
UPDATE: for some reason, synaptic managed to reinstall the package in place, whereas I couldn't get it to reinstall using the command line. Anyway, it is fixed, so, I guess the lesson is go for the simple answer first...
Thanks to N0rbert for the help.
dombov
