I wonder if someone can help me ,
when I try install or remove a package , this is the error I get
dpkg: error processing package libdrm-nouveau2:i386 (--configure):
 package is in a very bad inconsistent state; you should
 reinstall it before attempting configuration
dpkg: dependency problems prevent configuration of libgl1-mesa-dri:i386:
 libgl1-mesa-dri:i386 depends on libdrm-nouveau2 (>= 2.4.38); however:
  Package libdrm-nouveau2:i386 is not configured yet.
dpkg: error processing package libgl1-mesa-dri:i386 (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
When I try remove the package I get this error :
sudo apt-get remove libdrm-nouveau2
Reading package lists... Done
Building dependency tree
 account-plugin-facebook : Depends: libaccount-plugin-generic-oauth but it is not going to be installed or
                                    ubuntu-system-settings-online-accounts but it is not going to be installed
 indicator-bluetooth : Depends: unity-control-center but it is not going to be installed or
                                gnome-control-center but it is not going to be installed or
                                ubuntu-system-settings but it is not going to be installed
 indicator-network : Depends: unity8 (>= 7.82) but it is not going to be installed
 libegl1-mesa : Depends: libgbm1 (>= 7.11~1) but it is not going to be installed
                Recommends: libegl1-mesa-drivers
 libmirserver18 : Depends: libmirplatformgraphics-mesa (= 0.1.8+14.04.20140411-0ubuntu1) but it is not going to be installed or
                           libmirplatformgraphics-android (= 0.1.8+14.04.20140411-0ubuntu1) but it is not going to be installed
 libqt5gui5 : Depends: libgbm1 (>= 8.1~0) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Tim
  • 33,500
According to Ubuntu Community Help Wiki, try running:
sudo apt-get -f install
From the help page,
This command does the same thing as Edit->Fix Broken Packages in Synaptic. Do this if you get complaints about packages with "unmet dependencies".
Then if you still experience problems, run sudo apt-get check and report back.
daltonfury42
  • 5,559
