143
I get this error whenever I try to install programs using the terminal:
home@ubuntu:~$ apt-get install myunity
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
Also I'm unable to install updates using the terminal.
Braiam
  • 69,112
7 Answers7
149
The solution is to read the error message: are you root?
Use sudo to run a command with root privileges, like this:
sudo apt-get update
Nmath
  • 12,664
pzkpfw
  • 5,743
31
According to the community documentation about using the terminal,
sudo: Executing Commands with Elevated Privileges
  1. Most of the following commands will need to be prefaced with the sudo command. This elevates privileges to the root-user administrative level temporarily, which is necessary when working with directories or files not owned by your user account. When using sudo you will be prompted for your password. Only users with sudo (administrative) privileges will be able to use this command. You should never use normal sudo to start graphical applications as Root (Please see RootSudo for more information on using sudo correctly.)
So, because apt-get installs software and thus affects the system, you need to use the sudo command to give yourself administrator privilages.
Thus, you command should be sudo apt-get install myunity
If you want to update your system, run
sudo apt-get update
sudo apt-get dist-upgrade
This will update your system's package database and then install any upgrades.
iBelieve
  • 5,434
13
Before running any administrative task: installing, removing, changing system wide preferences, etc. you need to be root. This is specially true for apt-get. The message itself tells you where the problem is:
are you root?
If you are not root, the install command will not work at all.
The way to fix this is using sudo before the command:
➜  ~  apt-get update
E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
E: Unable to lock directory /var/lib/apt/lists/
➜  ~  sudo apt-get update
Fetched 616 kB in 25s (23.9 kB/s)
As you can notice, it completed without problems when I used sudo. If you have any open (13: Permission denied) it is almost sure that you are not root and need to use sudo.
Braiam
  • 69,112
Try with
sudo apt-get update
If you still get lock error try this command It will give the process detail
ps -e | grep -e apt -e adept | grep -v grep
Then kill the process using process ID then execute the update command
And also u can delete this file your problem will solve
rm /var/lib/dpkg/lock
Artur Meinild
  • 31,035
Premkumar
  • 351
just run
sudo apt-get update
sudo is for running it as super user
Stormvirux
  • 4,536
Just read the error output: are you root? because you are not. As a regular user you don't have enough privileges to install packages.
Prepend sudo to the command to elevate the privileges. Provided that account has sudo privileges that will work.
gertvdijk
  • 69,427
I had this error and in my case I had to remove noexec on /var in /etc/fstab
which works fine on my CentOS, Fedora and Alpine Linux
JOduMonT
  • 397
