I had problems with Google Earth, so I followed this link's recommendations, which had me installing the googleearth-package package. I'm new to Ubuntu, so mid installation I got cold feet (not really understanding what I was installing or whether doing it was safe) and aborted it here:
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
build-essential dpkg-dev fakeroot g++ g++-7 gcc gcc-7
gcc-8-base:i386 libalgorithm-diff-perl libalgorithm-diff-xs-perl
libalgorithm-merge-perl libasan4 libasn1-8-heimdal:i386 libatomic1
libc-dev-bin libc6:i386 libc6-dev libcilkrts5 libcom-err2:i386
libdb5.3:i386 libfakeroot libffi6:i386 libgcc-7-dev libgcc1:i386
libgmp10:i386 libgnutls30:i386 libgssapi3-heimdal:i386
libhcrypto4-heimdal:i386 libheimbase1-heimdal:i386
libheimntlm0-heimdal:i386 libhogweed4:i386 libhx509-5-heimdal:i386
libidn2-0:i386 libitm1 libkrb5-26-heimdal:i386 libldap-2.4-2:i386
liblsan0 libmpx2 libnettle6:i386 libp11-kit0:i386 libquadmath0
libroken18-heimdal:i386 libsasl2-2:i386 libsasl2-modules:i386
libsasl2-modules-db:i386 libsqlite3-0:i386 libssl1.1:i386
libstdc++-7-dev libtasn1-6:i386 libtsan0 libubsan0
libunistring2:i386 libwind0-heimdal:i386 linux-libc-dev make
manpages-dev zlib1g:i386
Suggested packages:
debian-keyring g++-multilib g++-7-multilib gcc-7-doc
libstdc++6-7-dbg gcc-multilib autoconf automake libtool flex bison
gcc-doc gcc-7-multilib gcc-7-locales libgcc1-dbg libgomp1-dbg
libitm1-dbg libatomic1-dbg libasan4-dbg liblsan0-dbg libtsan0-dbg
libubsan0-dbg libcilkrts5-dbg libmpx2-dbg libquadmath0-dbg
glibc-doc:i386 locales:i386 glibc-doc gnutls-bin:i386
libsasl2-modules-gssapi-mit:i386
| libsasl2-modules-gssapi-heimdal:i386 libsasl2-modules-ldap:i386
libsasl2-modules-otp:i386 libsasl2-modules-sql:i386
libstdc++-7-doc make-doc
Recommended packages:
libgnutls26:i386
The following NEW packages will be installed:
gcc-8-base:i386 googleearth-package libalgorithm-diff-perl
libalgorithm-diff-xs-perl libalgorithm-merge-perl libasan4
libasn1-8-heimdal:i386 libatomic1 libc-dev-bin libc6:i386
libc6-dev libcilkrts5 libcom-err2:i386 libdb5.3:i386 libfakeroot
libffi6:i386 libgcc-7-dev libgcc1:i386 libgmp10:i386
libgnutls30:i386 libgssapi3-heimdal:i386 libhcrypto4-heimdal:i386
libheimbase1-heimdal:i386 libheimntlm0-heimdal:i386
libhogweed4:i386 libhx509-5-heimdal:i386 libidn2-0:i386 libitm1
libkrb5-26-heimdal:i386 libldap-2.4-2:i386 liblsan0 libmpx2
0 upgraded, 58 newly installed, 0 to remove and 4 not upgraded.
Need to get 34.9 MB of archives.
After this operation, 146 MB of additional disk space will be used.
Do you want to continue? [Y/n] n
Abort.
So my next step was to uninstall whatever did get installed before I aborted; so I did this:
sudo dpkg -P googleearth-package
And I got this:
dpkg: warning: ignoring request to remove googleearth-package which isn't installed
So I tried:
apt list 'googleearth*'
Listing... Done
googleearth-package/bionic,bionic 1.2.2 all
So then:
apt remove googleearth-package
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
And then I didn't know what else to do so I came for your help, please.
Thanks.
