When I try to download anything at all through the terminal on 16.04, it doesn't finish something as I do this command: sudo apt-get install kdenlive. It then tells me Unmet Dependencies. Try 'apt-get -f install' with no packages (or specify a solution). But then when I try apt-get -f install it says,
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
What does this mean? I think it means root or moderator of the computer, but I am moderator of the computer already. Please tell me what I can do :(
Make sure you don't have another update application open: eg Synaptic, Software Updater, Ubuntu Software, another terminal. Then, as @Dave Sha points out, try using sudo apt-get -f install.
Jaydin
  • 1,571
